Pages: 1 ... 32 33 34 35 36 37 38 [39] 40 41 42   Go Down
Author Topic: Engine noise, terminal?  (Read 117692 times)
Re: Engine noise, terminal?
« Reply #570 on: 11 April 2010, 20:10:04 »
With the scuttle on, you can't hear the noise  :-/
That made me concerned all the way home, as that was what I was going to be listening for.
Took it easy - 70-80mph - all the way, but the A43 got boring ::).  Didn't go mad, but it did cruise up to above 3k rpm.
Just put out the 2nd light on the LPG gauge as I pulled up.  40miles calibrating, and 140m home.
Sounds about right ;)
Did think it would sound much quieter with the scuttle on.
Any lag/hesitation on the LPG front?
[edit]Just seen your next post ::)
I think I'll be dropping the pressure on mine again and experimenting some more :-/[/edit]
Lag - impossible to tell, as I was being a good boy - for 130m, didn't go about 3k rpm, and at no point was it floored.
« Reply #571 on: 11 April 2010, 20:10:39 »
sounds good progress...
refresh my memory....was it an oil pump or pas pump you did (well Tony did) at Newent?
PAS
« Reply #572 on: 11 April 2010, 20:11:42 »
PAS
« Reply #573 on: 11 April 2010, 20:17:12 »
delighted, excellent news, well done "team"... ::) ;)
We decided that you might have been the "Curse" as you weren't here today ::) ::) :D :D :D
yeah yeah, notice i congratulated the team, not the manager...
 ;D ;)
just prooves the fault lay with the grumpy car and owner, obviosly...we did our bit no problem. :y
« Reply #574 on: 11 April 2010, 20:38:02 »
 ;D ;)
In all seriousness, it was one of those dreadful coincidences that would probably have been one of the first things checked if the LPG work hadn't been done :y :y
Definitely seems to be related to oil temperature (and thus pressure) :-/
Have you got an oil pressure tester Mr DTM?  :y
« Reply #575 on: 11 April 2010, 20:53:59 »
 ;D ;)
Should have by the end of this week
« Reply #576 on: 11 April 2010, 21:10:47 »
 ;D ;)
Excellent... I'm sure TB is willing for you to try it out on a certain silver car ::) ::)
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #577 on: 11 April 2010, 21:12:51 »
Fascinating thread.
Next suspect is oil pressure relief valve sticking? Or have I missed the point somewhere?
Work is the curse of the drinking classes (Oscar Wilde)
« Reply #578 on: 11 April 2010, 21:21:39 »
Fascinating thread.
Yep... Could be other things too but definitely seems to be a pressure issue when the oil is hot (and thinner)
Fine under gentle driving conditions but not happy when driven hard for a sustained period ::)
[edit]Should add... Was suspect when the car was collected from MDTM :y[/edit]
« Last Edit: 11 April 2010, 21:22:41 by Lazydocker »
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #579 on: 11 April 2010, 21:23:14 »
Fascinating thread.
Fine under gentle driving conditions but not happy when driven hard for a sustained period with TB's lead foot ::)
Fixed that for you Paul. ;D ;D
TuBy's new whipping boy.
« Reply #580 on: 11 April 2010, 21:25:32 »
Fascinating thread.
Is there any other way?
The noise can't be heard in the car with scuttle on, but I'm sure I would have noticed it before with bonnet up, and Kevin Wood would have noticed when I drove into his garage.
I still don't believe in coincidence  :-/
« Reply #581 on: 11 April 2010, 21:35:21 »
Fascinating thread.
I must confess, it's still hard to accept. But as we said, if you hadn't done any work you'd have looked at lifters much earlier in the diagnosis.
Just hope that it's fairly simple to put right.
« Reply #582 on: 11 April 2010, 23:22:09 »
I think checking the oil pressure is the next move - before it's driven hard, just in case.
To that end, if the thread's the same, you are welcome to borrow the pressure gauge off the Westfield for a while? Just thinking it can be chucked on top of the dash so you can keep an eye on it while driving.
« Reply #583 on: 12 April 2010, 08:00:09 »
In a tunnie style gaffer tape setup ;D ;D ;D
« Reply #584 on: 12 April 2010, 09:07:42 »
The only way to bodge, is tunnie style  8-)
Pages: 1 ... 32 33 34 35 36 37 38 [39] 40 41 42   Go Up
