Author Topic: help required wet passenger side foot well  (Read 1752 times)
smartrs
  • out in the sticks
« on: 19 May 2010, 13:47:17 »
missus just brougt the car home from work and has said the passenger side footwell is a little wet afterthe air con has been on , only just had this re gased the car is a 2.6 v6 cdx , is there any thing i need to be checking ?
many thanks
Re: help required wet passenger side foot well
« Reply #1 on: 19 May 2010, 13:51:16 »
many thanks
Sounds as though the scuttle drain is blocked.  ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083  :y
« Last Edit: 19 May 2010, 13:52:27 by Andy_B »
smartrs
  • out in the sticks
« Reply #2 on: 19 May 2010, 14:01:52 »
just had a look at the one below the pollen filter does seem to have a few leaves at the bottom looks like ive found my job for te weekend  ;)
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« Reply #3 on: 19 May 2010, 15:10:45 »
Have a look under the scuttle n/s. Is there any water in there? There's a grommit right down at the bottom where muck (for want of another word!) settles and needs to flow out. Only place it can go is normally into the passenger footwell. So get your hand as far down as u can (unless u have fat fingers!) & see if u can feel the gromit if not i used a long screwdriver until i pushed the gromit out followed by mucky water. Then u can give it a good clean whilst the gromits dislodged  :y
On the other hand it cud be your HBV leaking but first things first  :)
smartrs
  • out in the sticks
« Reply #4 on: 19 May 2010, 15:26:07 »
there is a couple of leaves but nothing major no build up of water
eliteomegaman
« Reply #5 on: 19 May 2010, 16:42:55 »
Have u checked the coolant level for loss of water  :-?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #6 on: 19 May 2010, 18:13:35 »
Check Sunroof drains too
