Author Topic: gunk  (Read 2527 times)
nmp
  • burntwood, staffordshire
gunk
« on: 19 May 2010, 16:14:31 »
I took my oil cap off today to find some white gunk inside, is this the sign of knackered head gaskets?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: gunk
« Reply #1 on: 19 May 2010, 16:24:59 »
not normally on the v6 unless you have an unexplained coolant loss,mine does the same thing when used on short trips,a good run with the pikey wagon cleaned mine up a treat
other rides
nmp
Re: gunk
« Reply #2 on: 19 May 2010, 16:27:16 »
the rocker gaskets also leak a little along with the front wishbones need replacing do you think its safe on a long journey?
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
Re: gunk
« Reply #3 on: 19 May 2010, 16:30:01 »
Yes, but will cost you in oil & tyres.
nmp
Re: gunk
« Reply #4 on: 19 May 2010, 16:32:01 »
would wynns stop leak stop the rocker gasket leak until i get them replaced?
henryd
  • west cornwall
Re: gunk
« Reply #5 on: 19 May 2010, 16:33:55 »
very unlikely :(
other rides
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
Re: gunk
« Reply #6 on: 19 May 2010, 17:08:26 »
white gunk is probably condensation from short journeys - key to HGF would be coolant going down as mentioned, or white gunk on bottom of dipstick, white smoking etc etc..
Italian Tune it.
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
Re: gunk
« Reply #7 on: 19 May 2010, 17:14:48 »
If you have only been doing short journeys then u will get white yoghurt on your filler cap so if you are going on a long trip you should notice that when you have cleaned off the gunk its gone  :y
Do check that u havnt got oil particles in your coolant tank or/and water drops on your oil dip stick cos that cud point to HG problem  :'(
As for your front wishbones u will notice wear on your front tyres & the car will shudder when u brake hard  :(
As for Wynns stop leak DONT waste your money cos it WONT  stop the rocker gasket covers leaking  :(
nmp
Re: gunk
« Reply #8 on: 19 May 2010, 17:29:15 »
but are all these problem safe to do a 500 mile round trip,mainly motorways?
henryd
  • west cornwall
Re: gunk
« Reply #9 on: 19 May 2010, 17:33:30 »
if the cam covers are leaking over the manifolds then there is a small risk of it igniting
other rides
nmp
Re: gunk
« Reply #10 on: 19 May 2010, 17:36:45 »
there is a smell of burning oil when the engine is hot
eliteomegaman
Re: gunk
« Reply #11 on: 19 May 2010, 18:07:54 »
I'll probably be shot down in flames from the 'governers' on this site  :-[ BUT i've owned enough V6 migs with leaking rocker covers (as long as its not p*ssing oil  :o) to say that as long as u keep a watchful eye on ur oil level then a 500mile should present u with little probs  :y
Just remember that ur wishbones are going to make ur braking shudder so try not to be heavy footed on the brakes unless in an emergency  :o
The choice, as they say, is all yours  :-/
Re: gunk
« Reply #12 on: 19 May 2010, 18:12:28 »
bit of 'mayo' on the cap is normal, especically with short journeys, and some oils are far more prone to this than others.
castrol, Mobil 1, some other cheap oils often mayo more then vauxhalls own which doesnt suffer half as badly.
nmp
Re: gunk
« Reply #13 on: 19 May 2010, 18:19:30 »
Thanks everyone for your helpful advice.
Re: gunk
« Reply #14 on: 19 May 2010, 18:58:13 »
At some point, the oil leaking from the gaskets into the plug wells will cause damage to the HT side of the ignition system.You will get a misfire from damaged plug leads and/or dispack. Best to get them changed sooner rather than later. :y
