Author Topic: Timing tolerance  (Read 1123 times)
Omegafantasy
  • Oslo, Norway
Timing tolerance
« on: 21 May 2010, 21:19:04 »
Hi folks,
Just a quick question here as I can't find any information elsewhere.
What is the maximum error in timing before interference on a V6? In this case it's a Y26SE.
Say one camshaft had one tooth wrong, or all cams?
I have to take off my cover tomorrow and have a look to see if there's any wear on the belt and how the tension is. Might as well have a look at the timing when I'm in there.
I have some trouble finding the source for my misfire/wobbling sound when flooring it below 4000 rpm. Actually had a EML light today, but that was just the air temp sensor plug that fell off (missing the locking clip) :(
1995 Omega 2.6 V6 Estate ("fresh" engine) Drives like a 2-litre. Grr! Gettin' dusted by a 1.8 auto Cav..
1991 Omega 3000-24v (major rust job)
(Interested in buying Vauxhall emblems/grille for my V6)
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Timing tolerance
« Reply #1 on: 22 May 2010, 19:06:41 »
should be on timing marks for tolerance, new,old or 2 lines.
« Reply #2 on: 22 May 2010, 22:55:00 »
Generally up to 2 teeth is OK, 3rd tooth often means tears at bedtime
Omegafantasy
  • Oslo, Norway
« Reply #3 on: 23 May 2010, 03:57:12 »
Thanks guys :)
Then I might get a feeling how bad things are when I dismantle my old engine and checking my new one.
