Author Topic: Water Loss  (Read 942 times)
Michael Bairstow
  • London
Water Loss
« on: 23 May 2010, 15:53:47 »
I am having a problem with slight water loss I've tried K seal which was fine for a short while but the problem has returned is it the head gasket and if so what is a realistic garage price
Re: Water Loss
« Reply #1 on: 23 May 2010, 15:56:12 »
Where's it leaking from?
Usual culprit on V6s is the HBV at rear of plenum.
Michael Bairstow
  • London
Re: Water Loss
« Reply #2 on: 23 May 2010, 16:01:19 »
I cant see any leaks but I have to top up about a pint everyday, whats the HBV you mensioned
Re: Water Loss
« Reply #3 on: 23 May 2010, 16:03:28 »
Heater Bypass Valve - sits behind plenum drivers side - you can just get your hand down to feel for wetness - there are 3 water hoses connected plus a vacuum pipe on top.  Looks like Starship Enterprise!!
Michael Bairstow
  • London
Re: Water Loss
« Reply #4 on: 23 May 2010, 16:07:14 »
Thanks debug I'll check that out and get back to you if you don't mind
Re: Water Loss
« Reply #5 on: 23 May 2010, 16:07:55 »
Thanks dbug I'll check that out and get back to you if you don't mind
« Last Edit: 23 May 2010, 16:08:23 by dbug »
Michael Bairstow
  • London
Re: Water Loss
« Reply #6 on: 23 May 2010, 16:24:14 »
Hi dbug you are right I can see the staining from the K seal.
Have you any idea how much Vauxhall charge for replacement Valve
Re: Water Loss
« Reply #7 on: 23 May 2010, 16:31:32 »
On TC card I paid just over £30 for genuine Vx one recently.  Do NOT buy the cheapos off ebay - they will leak.
Fiddly to swap - look here for howto - http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
