Author Topic: Lack of power under 2500rpm Help!!!  (Read 2472 times)
hacked offf
« on: 24 May 2010, 10:58:29 »
hello to everyone i know this problem must have been disscused before my 2.5v6 has no pulling power i could hear an air leak so i had the plenum off it was definatly leaking, took it off, trapped wire in there (must have been when LPG was fitted) cleaned it replaced o rings refitted it, started it up even less power than before no misfires! Help!!! can some kind person point me in the right direction,
Thanks :-[
Re: Lack of power under 2500rpm Help!!!
« Reply #1 on: 24 May 2010, 11:04:51 »
Hello & Welcome.
1st this is to check for fault codes, use the link in my sig for a how2.
Apart from that, airleak now gone?  car serviced well?  is this on lpg or petrol, or both?
« Reply #2 on: 24 May 2010, 11:07:24 »
Hello and welcome to the forum. :y
Are you seeing a lack of power on both petrol and LPG or just LPG?
I am thinking that, if the LPG system was calibrated with a huge air leak, it will need to be recalibrated now. If it doesn't run well on petrol I would say you have another problem somewhere, though.
If it's recently been converted and has run poorly since, I would take the car back to the garage who did the conversion and point out their error as a first step.
If that doesn't bear fruit there is plenty of LPG knowledge on here. :y
hacked offf
« Reply #3 on: 24 May 2010, 11:22:15 »
Thanks guys really quick replies, No Fault codes, it is doing it on both petrol and LPG ? the conversion was four years ago.
« Reply #4 on: 24 May 2010, 11:36:51 »
both multirams working properly?
hacked offf
« Reply #5 on: 24 May 2010, 11:42:21 »
Thanks TheBoy dont know, how will i test them? i know months ago there is a small black box at the bottom for the radator that has a vacum pipe that go's to the multi rams this was broken i have boged it up
RobG
    • 16 plate Mokka. Vivaro
« Reply #6 on: 24 May 2010, 12:00:23 »
Blip the throttle. Rear should kick in around 1000rpm front around 4000rpm
« Reply #7 on: 24 May 2010, 12:13:59 »
Ah, thats the vac reservoir for the multirams. Has it been poor since then?
hacked offf
« Reply #8 on: 24 May 2010, 12:34:56 »
Thanks , it was poor before i found the vac res pipe fitting was broke as i said before i thought i'd fixed it how will i know if thats the problem and if the multi rams are working ,would that account for the total loss of power it is driving like a old slow tractor.
hacked offf
« Reply #9 on: 24 May 2010, 13:48:45 »
will putting the small pipes on the plenum in the worng order affect the whole air problem?
RobG
« Reply #10 on: 24 May 2010, 13:56:36 »
hacked offf
« Reply #11 on: 24 May 2010, 20:46:58 »
hi guys Just done the paper clip test got theses results
No 33 X 3  EGR valve voltage low
No 57 X 3 idle air control voltage low
No 74 X 3 mass air flow sensor voltage high
No 129 X 3 EGR valve feedback voltage low
what is do you think is my best course action :'(
RobG
« Reply #12 on: 24 May 2010, 20:50:27 »
Disconnect the MAF and try it. Other codes possibly relate to low battery
hacked offf
« Reply #13 on: 24 May 2010, 21:14:44 »
There are 2 plugs that into the big pipe from the air filter which one should i disconect?  and what will it do when it is disconected?
hacked offf
« Reply #14 on: 24 May 2010, 21:50:48 »
Just unpluged air mass meter just made it worse tried to drive it just no power HOW SLOW!
