Author Topic: More airbag weirdness.  (Read 2290 times)
Re: More airbag weirdness.
« Reply #15 on: 22 May 2010, 21:51:42 »
aye, its the what have you got to do on the next one...
the engine is so sweet, even approaching 140k, after Marks HG etc work, it really does drive beautifully.
Its one of those cars I am unreasonably attached too, just can't see past those jobs, the oil leak especially, cam cover done 3 times, and still has a very intermittant leak somewhere, leaks and smokes like hell, then nothing for weeks.  I dunno, fed up with it.  been battling that airbag issue for 3 years.  Very, very sorry to say it, but I think the end is coming.  :'( :'( :'( :'( :'(
Thats how it got with mine after 5 years, had trouble free motoring for 4 years, then eveything seems to come at once with Omega's  :'(
  • Auckland
    • Mazda MPV
« Reply #16 on: 22 May 2010, 22:03:09 »
If it isn't the plug then maybe it is the crimped connections in the pins in the plug :-/
Crimped connections are generally reliable but maybe GM trapped the insulation in one of the pins in your connector.
« Reply #17 on: 22 May 2010, 22:08:11 »
... cam cover done 3 times, and still has a very intermittant leak somewhere, leaks and smokes like hell, then nothing for weeks.  ...
Yep... Mine have no outward signs of leaking but got a puff of smoke the other day... 8 or 9 months ago had a little (and it was a little) oil in the plug wells... But not a regular leak and no evidence of it :-/ :-/
« Reply #18 on: 22 May 2010, 22:15:19 »
Just connect a pipe to a bin liner and place it on the side of your seat wit the pipe under the seat.
If you get into a 'situation' your farts would be enough to inflate a small bouncy castle!
« Reply #19 on: 22 May 2010, 22:54:34 »
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #20 on: 23 May 2010, 09:00:58 »
Less of the 'small' please  :y
« Reply #21 on: 27 May 2010, 19:47:44 »
battery disconnect test in progress....
« Reply #22 on: 27 May 2010, 20:11:19 »
Well, disconnecting the battery made no difference, seat back off, connector off, quick spray of cleaner and reassemble, and jobs a goodun.
I give up, ill just do this every now and again....
FYI
Measure, Original data, after disconnect, after connector reseat
System Voltage      13.59 V      13.98 V      13.79 V
System Voltage Status      Okay      Okay      Okay
Airbag Configuration      Side Airbags      Side Airbags      Side Airbags
Pretensioner Configuration      Driver&Passenger      Driver&Passenger      Driver&Passenger
Driver Airbag Squib Circuit Resistance      3.13 Ohm      3.03 Ohm      3.05 Ohm
Passenger Airbag Squib Circuit Resistance      2.17 Ohm      2.12 Ohm      2.10 Ohm
Driver Pretensioner Circuit Resistance      2.59 Ohm      2.61 Ohm      2.56 Ohm
Passenger Pretensioner Circuit Resistance      2.43 Ohm      2.41 Ohm      2.41 Ohm
Driver Side Airbag Squib Circuit Resistance      5.15 Ohm      5.15 Ohm      3.42 Ohm
Driver SAS Message Status (Side Airbag Sensor)      Okay      Okay      Okay
Passenger Side Airbag Squib Circuit Resistance      2.46 Ohm      2.43 Ohm      2.43 Ohm
Passenger SAS Message Status (Side Airbag Sensor)      Okay      Okay      Okay
Reset Passenger Side Airbag After Activation (DTC69)      Inactive      Inactive      Inactive
Reset Driver Side Airbag After Activation (DTC68)      Inactive      Inactive      Inactive
Reset Pretensioning Devices After Activation (DTC67)      Inactive      Inactive      Inactive
Driver SAS Initialisation Status (Side Airbag Sensor)      Okay      Okay      Okay
Driver SAS Communication Error (Side Airbag Sensor)      None      None      None
Passenger SAS Initialisation Status (Side Airbag Sensor)      Okay      Okay      Okay
Passenger SAS Communication Error (Side Airbag Sensor)      None      None      None
DTC set since      21000      21000      21000
