Author Topic: Forte engine treatments  (Read 1486 times)
Rob James
  • Sheffield
« on: 28 May 2010, 13:49:44 »
Hi,
I've used the Forte Advanced Formula Gas Treatment previously. What I'm wondering is, if I use that is there any need to use the Specialist Fuel Injector Cleaner i.e. does the gas treatment also clean the injectors?
Cheers,
Rob.
« Last Edit: 28 May 2010, 13:51:47 by bobbyg »
Re: Forte engine treatments
« Reply #1 on: 28 May 2010, 14:03:23 »
I just use the one you have, never needed any more than that.
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 28 May 2010, 14:47:50 »
I've used STP fuel injector cleaner (Forte not available here) and must say it makes a difference, car works better (smoother) consupmtion dropped (only slightly) and also noticed it reves a little better
« Reply #3 on: 28 May 2010, 15:52:31 »
I use Forte to clean the injectors....    ....I wonder if my brother will mind if I put them in his ultrasonic baths he uses for cleaning jewellery ::)
Page created in 0.038 seconds with 16 queries.
