Author Topic: front door solenoid failure  (Read 3893 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
« on: 27 May 2010, 18:52:15 »
In OOf's members opinions, if the drivers solenoid has failed completely after working intermitantly for a day, is it likely to be knackered or is there a glimmer of hope that it may need cleaning and lubing!
stuck at inlaws for a few days and have the time to strip the door down, but if it needs replacing don't know anyone near here that has a trade club card, or infact where a local dealer is
www.impactcls.co.uk - Flight Case Manufacture
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: front door solenoid failure
« Reply #1 on: 27 May 2010, 19:02:57 »
Think I read here recently that the door 'solenoid' is actually a motor, worth cleaning and lubing in my opinion  :y
Jon
« Reply #2 on: 27 May 2010, 19:08:54 »
have the same problem.. tried lubing..
but no chance , needs changing now :-/
Impact Pete
  • Derby
« Reply #3 on: 27 May 2010, 19:11:26 »
Jon
thats what i'm thinking, use the term solenoid but I think your right it's a motor, certainly listed as motor on spares
Welung666
« Reply #4 on: 27 May 2010, 20:02:04 »
I've got one here Pete if you're stuck :y
Impact Pete
  • Derby
« Reply #5 on: 27 May 2010, 20:13:12 »
excellent :y, I will have a look over weekend and as I suspect if is knackered how much do you want for it, back in the midlands thur next week
Welung666
« Reply #6 on: 27 May 2010, 20:17:11 »
I've got it in the portable parts store car already ;) Will you be passing me on your way home? If you are pop in, have a cuppa and I'll stick it on for you ;) :y
Impact Pete
  • Derby
« Reply #7 on: 27 May 2010, 20:31:08 »
I will be coming up M1 to Derby but as much as I would be happy to stop by the wife would not! >:(
She laughs at me for my dedication to fixing the car up but as I have pointed out if we had followed a garages opinion our lovely car would be on the scrap heap, but after the run down here to kent 200 miles at 75mph the car has proved itself after all the work and tweeking as we managed a 34mpg average highest so far in last 3 years, first time that we have arrived with more than half a tank of petrol! :)
well chuffed 8-)
Steveplumb
  • Radstock, Near Bath
« Reply #8 on: 27 May 2010, 20:37:38 »
Having striped one down a couple of weeks ago i am pretty sure it is the micro switches at the end of travel of the worm drive linked to the motor that fail or go ' intermitant' The motor itself was absolutely  fine.  Didn't really do anything to it but when I put it back it worked fine  ................................................ for 2 weeks then failed again . Have now got a replacement from the scrap yard ..so its a chance how long it will last .  We really ought to source replacement switches , they would only cost pence and replacement didn't look too tricky  hmmm  can I be bothered ?
Impact Pete
  • Derby
« Reply #9 on: 27 May 2010, 20:43:21 »
I know the feeling I would think the replacing the whole unit with a second hand one is cheapest easiest option
Welung666
« Reply #10 on: 27 May 2010, 20:57:17 »
Pete will you be coming to the June ABS/OOF meet at the Plank? I can do it then if you are ;) If you don't mind I'll have your old one and look into the microswitch options, see if I can't get a repair service going ;) :y
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #11 on: 27 May 2010, 21:26:48 »
Maybe this is not appropriate to your actual fault, but a few years ago I had a Senator that had drivers door locking problems. It turned out to be a broken wire between door and door pillar.
My Omega has this locking fault now, and whilst delving into the dreaded retaining arm ripping out syndrome, when manipulating the wires, the locking suddenly worked.  :) I suspect a broken wire  again.!!!
Just food for thought :y
« Last Edit: 27 May 2010, 21:27:18 by terbert1 »
Impact Pete
  • Derby
« Reply #12 on: 27 May 2010, 22:39:38 »
hi no definately not wiring it still has power to it all fine, good idea though :y
Impact Pete
  • Derby
« Reply #13 on: 27 May 2010, 22:42:08 »
would like to, when is it again?
« Reply #14 on: 28 May 2010, 10:32:19 »
Right on the money :y
I suspect the grease gets into them or something.
If going to the trouble of taking the door card off, etc. I would have a known good motor to hand just in case.
Might as well clean up the lock mechanism and re-lube it with some white grease while it's out but, IME, it's not normally a stiff mechanism that causes the problem.
I have a failed motor that I've been meaning to dissect. I recall a member was able to source a replacement microswitch from Maplin which fitted with a bit of modification. Going back a year or two now.
Page created in 0.051 seconds with 16 queries.
