Author Topic: front door solenoid failure  (Read 3891 times)
Welung666
Re: front door solenoid failure
« Reply #15 on: 28 May 2010, 12:35:11 »
Pete will you be coming to the June ABS/OOF meet at the Plank? I can do it then if you are ;) If you don't mind I'll have your old one and look into the microswitch options, see if I can't get a repair service going ;) :y
would like to, when is it again?
2nd Sunday of every Month :y
bodach
  • Inverness,Highlands, Scotland
« Reply #16 on: 29 May 2010, 11:45:40 »
Hi Guys
I had this problem a few months ago, I removed the solenoid/motor I didnt have a replacement so put it all back together and it was worse than previously.
I read on the forum somewhere a guy had soaked it with WD40 and worked it manually for a while and it was fine.
So I took off the door panel again but this time left the solenoid/motor in situ and sprayed it with WD40 + worked it using the manual door lock lever/button lots of times, hey presto saved me 74 squids for a new one. Its still fine 2 months later.
There is a good guide to removing the door panel is on the forum.
Hard work keeps it on the road!!
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« Reply #17 on: 29 May 2010, 15:06:45 »
Hi Guys
So I took off the door panel again but this time left the solenoid/motor in situ and sprayed it with WD40 + worked it using the manual door lock lever/button lots of times, hey presto saved me 74 squids for a new one. Its still fine 2 months later.There is a good guide to removing the door panel is on the forum.
Great advice mate! i've got the same problem myself so will try it on mine & keep my fingers crossed!!  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #18 on: 29 May 2010, 17:51:10 »
Mine was sticky on and off Sprayed it with WD 40 and that killed it completely Got one from breakers and is ok at present
John Lewis
  • Macclesfield, Cheshire
  • Macc is wack
« Reply #19 on: 29 May 2010, 17:57:10 »
Done this job before, its not too hard at all, just make sure you've got every screw out, especially the one behind the door handle rubber and the door lever plastic, or you'll do your own head right in!
Might be in need of one myself shortly, anyone else got a spare one?
« Reply #20 on: 29 May 2010, 21:10:08 »
http://www.omegaowners.com/forum/YaBB.pl?num=1275155914
Hot off the press, by popular demand. :)
« Reply #21 on: 29 May 2010, 21:19:01 »
Quite impressive Kevin!  :y :y :y
I never have enough of my work bench free enough for such a major strip down!  ;) :y
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
« Reply #22 on: 30 May 2010, 12:44:24 »
nice one, the fact that it worked once yesterday makes me feel that it just needs a good clean.
waitin for better weather to get door card off
www.impactcls.co.uk - Flight Case Manufacture
