Author Topic: Airbag light  (Read 2533 times)
mrjimbo
  • Oxfordshire
Airbag light
« on: 28 May 2010, 05:54:42 »
On the way home from work this morning stopped at a set traffic lights at some roadworks pulled away and whilst going through the chicane the airbag light came on for no apparent reason now it won't go off. If you turn the ignition on all the warning lights come on and clear as normal but the airbag light comes back on after a couple of seconds   >:(
Anybody got any ideas as to whats going on there ?
Couldn't have happened any other weekend but i need the car on Sunday
  • Online Online
Re: Airbag light
« Reply #1 on: 28 May 2010, 05:58:22 »
There's a fault somewhere within the air bag system  ::) you'll need a code reader to find out exactly what. You can still use the car on Sunday, but if you crash you won't have an airbag ....... but we all managed for years without them.  :y
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #2 on: 28 May 2010, 06:16:43 »
Will a code reader tell where the fault lies exactly or just identify a general airbag fault ?
Will any code reader do or is it Tech2 only ?
SR-71 Blackbird
  • Watford and Nottingham Uni
Re: Airbag light
« Reply #3 on: 28 May 2010, 06:19:55 »
yes most likely is that the sensor got excited and signalled a fault which will cause the light to stay on forever until it is cleared with a tech2, probably a case of finding the problem sensor, unplugging, replugging and then having the tech 2 turn the light off, and then it will probably never come on again, well fingers crossed anyways :)
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #4 on: 28 May 2010, 06:30:05 »
Could possibly be the steering wheel airbag thinking about it.
I adjusted the steering wheel height when i was stopped at the traffic lights and when i moved off the adjuster clicked into one of the locating notches and a few seconds later the airbag light came on.
Where abouts would i find the steering wheel airbag sensor and is it easy to get at ?
Re: Airbag light
« Reply #5 on: 28 May 2010, 08:01:34 »
I wouldnt bother looking, chances are the fault has been and gone.
but once the airbag ecu sees a fault, the light is on (and protection off) until you reset with tech2, "My Naff Code Reader" or similar.
Theboy is close to your area with a tech2, could be worth getting in touch.
(due to a very weird fault, my airbag light is on more than its off, you can get used to the light, and miss it when its not there  ;D )
Re: Airbag light
« Reply #6 on: 28 May 2010, 08:38:32 »
No point guessing what it is, it needs to go on a code reader to discover why the light is on.
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #7 on: 28 May 2010, 14:47:47 »
Would you be available to have a quick look on Saturday ?
Re: Airbag light
« Reply #8 on: 28 May 2010, 15:53:43 »
What time? I have odds and ends I need to do....
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #9 on: 28 May 2010, 16:19:16 »
Whatever time is best for you really.
Could you program my spare key at the same time ?
Will need directions to find you  :y
You have PM
« Last Edit: 28 May 2010, 16:34:48 by mrjimbo »
Re: Airbag light
« Reply #10 on: 28 May 2010, 22:45:07 »
You have PM
PM replied to...
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #11 on: 29 May 2010, 02:31:06 »
You have PM
PM replied to...
See you in the morning  :y
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #12 on: 29 May 2010, 21:24:08 »
A big thank you to TheBoy for resetting my airbag light and checking for the fault responsible this morning, also programed my spare key for me at the same time  :)
Cheers mate, much appreciated  :y
Re: Airbag light
« Reply #13 on: 30 May 2010, 09:30:03 »
Always a pleasure :y.  Even if you did bring bad weather ;D
mrjimbo
  • Oxfordshire
Re: Airbag light
« Reply #14 on: 31 May 2010, 00:22:25 »
Did it get you out of doing the gardening ?
 ;D
