Author Topic: Dead MAF diags  (Read 1279 times)
Dead MAF diags
« on: 31 May 2010, 20:37:13 »
Anyone who's looked at a 3.2 or 2.6 with a MAF issue.
Ever seen no reading at all?  0 Volts etc?
If so did a new one fix it, or where else should I look?
Cheers
Re: Dead MAF diags
« Reply #1 on: 31 May 2010, 20:39:56 »
Cheers
Never seen one that bad.
It normaly reads high in my experience.
0 would sudgest an open circuit but it could be a very goosed sensor.....or another 'quirk' of the "My Naff Code Reader".
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Dead MAF diags
« Reply #2 on: 31 May 2010, 20:40:34 »
had faulty pedometer and gave no volts to maf
Re: Dead MAF diags
« Reply #3 on: 31 May 2010, 20:43:06 »
Cheers
thought it sounded weird..
plus have to select model 01 not 02 for "My Naff Code Reader" to work at all...
a dodgy reading I would be 'happy' with but no response seems weird.
on clearing the permanent code, it went to intermittant  :-/
Re: Dead MAF diags
« Reply #4 on: 31 May 2010, 20:45:00 »
should add I reseated the connector with no difference, and it drives beautifully, lots of go.
Re: Dead MAF diags
« Reply #5 on: 31 May 2010, 20:45:31 »
I smell an "My Naff Code Reader" odditiy
Re: Dead MAF diags
« Reply #6 on: 31 May 2010, 20:47:16 »
If only it was insured....could have been on route for a tech2 in the morning  :y
(and on that note....can I get you to check out that cruise control abnormality where it doesnt engage till decent speeds, see if the tech2 can see a reason, cheers  :y)
same #same#
  • south yorks
Re: Dead MAF diags
« Reply #7 on: 31 May 2010, 20:49:09 »
re install the drivers for "My Naff Code Reader" some driver issues
Re: Dead MAF diags
« Reply #8 on: 31 May 2010, 20:51:24 »
ill try it on a different computer and a different version tomorrow  :y
same #same#
  • south yorks
Re: Dead MAF diags
« Reply #9 on: 31 May 2010, 20:54:11 »
had no prblems with "My Naff Code Reader"090821D, no faults try that one.
Re: Dead MAF diags
« Reply #10 on: 31 May 2010, 20:54:57 »
it was  :y  can go back a fair few versions too, cheers  :y
