Author Topic: omega 3.0 elite facelift autobox probs??  (Read 3046 times)
matty
  • Nr Peterborough
« on: 02 June 2010, 19:21:19 »
I've recently got a 3.0 facelift elite estate with autobox problems, changed the oil today with dextro3 and mate who changed it drove it and said it was fine after, I picked it up and still slipping and won't change till near 4k roughly, I hit the accelerator and no joy it just looses power and revs just drop to idle!
Any ideas?
Re: omega 3.0 elite facelift autobox probs??
« Reply #1 on: 02 June 2010, 19:22:58 »
Did he change the oil using the guide on the forum?
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 02 June 2010, 19:28:44 »
how many liters of oil he use when done the job??
matty
  • Nr Peterborough
« Reply #3 on: 02 June 2010, 19:29:43 »
He's a mechanic and has his own place, took sump off drained it and filled it back up while running I think
serek
  • huntingdon
    • 3.2 mv6
« Reply #4 on: 02 June 2010, 19:37:08 »
so if he done job properly, sound like you got gearbox to replace :-[
matty
  • Nr Peterborough
« Reply #5 on: 02 June 2010, 19:38:55 »
7 I think he said,
If box is goosed I will break it I think! How much of a job is it to change the box?
« Last Edit: 02 June 2010, 19:42:48 by Matty »
unlucky alf
  • worksop, notts
« Reply #6 on: 02 June 2010, 19:41:29 »
might be worth dropping the small sump to see if its got bits of thrust washer in it. :(
matty
  • Nr Peterborough
« Reply #7 on: 02 June 2010, 19:45:52 »
He didn't say anything when he took the sump out said it was just dirty and old
serek
  • huntingdon
    • 3.2 mv6
« Reply #8 on: 02 June 2010, 19:49:38 »
7 I think he said,
if you got the garage with proper ramps 2-3h job
got spare gearbox here
can help if you will go to replace :y
« Last Edit: 02 June 2010, 19:51:47 by serek »
unlucky alf
  • worksop, notts
« Reply #9 on: 02 June 2010, 19:51:36 »
thats as maybe but he only needed to drop the large sump to do the filter & atf change, the washer if busted ends up in the small sump nearer the front, but either way the box will have to come out so youd be just as well to change it anyway, unless your mechanic knows how to fit a thrust washer if its gone.
matty
  • Nr Peterborough
« Reply #10 on: 02 June 2010, 20:10:34 »
Cheers guys, well I'm gonna put "My Naff Code Reader" on it at another mates tomoro see if that brings anything up!
Pm sent serek
matty
  • Nr Peterborough
« Reply #11 on: 02 June 2010, 20:36:37 »
If I get it up on ramps, take the bung out should the box be filled to brim? Just thinkin of seeing if it needs topped up
serek
  • huntingdon
    • 3.2 mv6
« Reply #12 on: 02 June 2010, 21:20:19 »
here how to check level
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
pm replay
matty
  • Nr Peterborough
« Reply #13 on: 02 June 2010, 21:55:37 »
Cheers for the help n advice serek! And the offer of the box, will double check levels tomoro if I can
