Author Topic: Thermostat link pipe Help!  (Read 1497 times)
Titanic
  • Birmingham
« on: 03 June 2010, 14:29:45 »
Does anyone know how to remove this link pipe??  I've been struggling with it for a while! does it pull out, screw out, push out.....Heeelllp!  :-[
mantahatch
Re: Thermostat link pipe Help!
« Reply #1 on: 03 June 2010, 14:33:38 »
I believe, if you have removed the bolt roughly beneath and forward of the oil filler, then it is just held on 2 O rings. That said often a bit of corrusion in the joint can cause it to stick.
HTH
Titanic
  • Birmingham
« Reply #2 on: 03 June 2010, 14:38:07 »
Thanks mate I Will try some elbow greese!
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 03 June 2010, 14:51:33 »
It is best to use two new O rings on refitting and possibly a new pipe.
Good luck with refitting. You need a bit of patience with that bolt!
« Reply #4 on: 03 June 2010, 15:08:12 »
I remove the two stat housing bolts and use a set of grips to rotate the stat housing on the link pipe to free it off before removing the B-bolt
Titanic
  • Birmingham
« Reply #5 on: 03 June 2010, 15:12:09 »
God! this is mad! this pipe wont budge - not to mention I do need a new one now ::)............ I would try that Mark but Ive gone too far now lol...wish me luck :-X
Titanic
  • Birmingham
Re: Thermostat link pipe Help! ITs Off!!!!!
« Reply #6 on: 03 June 2010, 15:21:58 »
I hit it then pryed it the twisted it then hit again then pryed it then................................it came off ............in three pieces!!!  ;D Its ok though as the leak was a hole in the link pipe and I need a new thermostat, thanks for your help lads!
« Reply #7 on: 03 June 2010, 17:29:20 »
Ive just bought a new tube ready for tackling this job  :y
are you meant to use any sealant on the new stat, or just oring?
seem to recall something about a smear of camcover goo worth applying?
  • Auckland
    • Mazda MPV
« Reply #8 on: 03 June 2010, 20:19:23 »
I used silicone grease on the ones I have put in.
The problem seems to be caused by coolant getting into the grooves behind the o-rings and the resultant corrosion expanding and crushing the o-rings. The corrosion appears to be slightly porous and acts as a wick which allows coolant to bypass the o-rings and escape (slowly).
gstylebaby
  • stockport
« Reply #9 on: 04 June 2010, 01:43:20 »
Mine needed a stat just after crimbo and i ended up brakeing the pipe also....Hope you have better luck than i did...Ive still got no heat in the cab. Gonna have to try and sort it once and for all before we get the cold weather again. >:( >:( >:(
« Reply #10 on: 04 June 2010, 07:13:17 »
try a heater matrix flush, guide in the maint section  :y
« Reply #11 on: 04 June 2010, 08:08:08 »
I use a wipe of oil cooler goo on the stat to block face.......and a wipe of grease on the link pipe O rings.
Link pipe is around a tenner with new seals
