Author Topic: ATF change  (Read 2860 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
ATF change
« on: 19 March 2010, 10:23:19 »
Despite having a replacement AR35 box to fit in the future, as the fitted AR25 seems quite happy, I have decided to replace the ATF to prolong its charmed life. Unfortunately I cannot find the 'How to' referred to in posts. I realise I have to drop the sumps and clean/replace filters - I have the set from JPAT- however if there is a 'How to ' so much the better. Could anyone supply the link please? :y
Cheers
Chris
PS Please can we get an end to TB's 'rattling' good saga, the suspense is killing me!
Re: ATF change
« Reply #1 on: 19 March 2010, 10:31:18 »
best we seem to have is the level check..
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Its not hard....
drop sumps, carefully as full of atf, I found partially undoing one side, fully undoing the rest helped as you can then 'slosh' some fluid out.
Then clean out the sumps, clean off old gasket from both faces.
3 bolts to drop and replace filter.
gaskets on, bolt it all back up, fill though the hole..
for that either use a big syringe, and squirt by squirt, or get a cheap 'killaspray' and pump that up for automated filling.
when full, start engine, go through all gears, and with car level, and running, do a final top up till the new atf just starts to overflow.
bolt back in and you are done.
Ive found a level check after a week or 2 has left it taking some more fluid.
« Last Edit: 19 March 2010, 10:31:55 by jimbob »
Re: ATF change
« Reply #2 on: 19 March 2010, 10:32:07 »
Not sure there is a guide, but feel free to take pics and do one :y :y
Undo filler - atf will come out
Remove front small sump - if bits of thrust washer in there, cry
remove rear sump
clean up gasket mating surfaces
renew filter (3? bolts)
replace sumps
fill to filler level with DIII
start car
refill back to filler level
run through all gears, check level again
Go for 10 mile blast, recheck level on return
Shackeng
  • Ramsbury
Re: ATF change
« Reply #3 on: 19 March 2010, 10:36:47 »
Thanks a lot JB and TB (who should be worrying about his head coming off!!!) Now off to get the DEX111, any preferred make? :y :y :y
Shackeng
  • Ramsbury
Re: ATF change
« Reply #4 on: 19 March 2010, 10:37:51 »
remove rear sump
replace sumps
start car
Just noticed that- Very amusing NOT! ;D ;D ;D
Re: ATF change
« Reply #5 on: 19 March 2010, 10:39:36 »
fuchs titan 4000 - try opie oils in parts section for a good discount  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1202469103
I tend to get 2 x 5 litres for plenty, and some left, just in case  :y
« Last Edit: 19 March 2010, 10:40:40 by jimbob »
Re: ATF change
« Reply #6 on: 19 March 2010, 10:42:00 »
ohh,,,,we both missed the final stage....
give overalls to someone to wash....several times
and shampoo hair 5-10 times to remove old atf  ;D ;D ;D
Re: ATF change
« Reply #7 on: 19 March 2010, 10:43:54 »
As per JB's reply, Fuch Titan 4000, treat yourself to 10l.
Opie Oils is a good supplier, and OOF get 10% off (see sticky in Parts For Sale section)
Re: ATF change
« Reply #8 on: 19 March 2010, 10:45:35 »
Not (too ::)) worried, MDTM is plenty familiar enough with taking the heads on and off my car.  Mind you, that in itself should be worrying - he is never shy to popping them off 'for a bit of fun' :o
Re: ATF change
« Reply #9 on: 19 March 2010, 10:47:46 »
yours have only been off once havent they?
your not a member of the exclusive twice off (in one week) club are you?
Re: ATF change
« Reply #10 on: 19 March 2010, 10:58:34 »
Think they are doing free delivery as well at the mo :y
Re: ATF change
« Reply #11 on: 19 March 2010, 11:00:21 »
Re: ATF change
« Reply #12 on: 19 March 2010, 11:11:39 »
In a few days, I may well join your club  :-X
Shackeng
  • Ramsbury
Re: ATF change
« Reply #13 on: 19 March 2010, 11:38:27 »
Thought so :y
http://www.omegaowners.com/forum/YaBB.pl?num=1268672823
Thanks a lot Pete, just placed my order, they have a new free shipping code now, I think its FREEMARCHSHIP.
 :y :y :y
Re: ATF change
« Reply #14 on: 19 March 2010, 11:45:06 »
Thought so :y
 :y :y :y
Now you need to see if wash and go do a similar offer  ;D
