Author Topic: Vac pipe connection query on V6 air cutoff valve  (Read 1668 times)
honestjohn
  • Kent
« on: 28 May 2010, 19:39:50 »
Just noticed that there is an empty vac connection elbow on the top of my 2.5 V6 air cutoff valve for the emission control system.
Is there a connection to be made? - I can see no spare vac pipes needing a connection.
The solenoid has a vac pipe on it that comes off back of plenum.
I have a pic but can't upload into message.
« Last Edit: 28 May 2010, 19:42:23 by honestjohn »
honestjohn
  • Kent
Re: Vac pipe connection query on V6 air cutoff valve
« Reply #2 on: 29 May 2010, 08:07:52 »
Thanks Rob,
It helps a lot. It shows there is only one vac line to the sec air inj set up, which I have re-connected as it was before I did the cambelt and water pump.
It still leaves me with a spare connection so maybe it was always that way :)
« Last Edit: 29 May 2010, 08:08:15 by honestjohn »
« Reply #3 on: 29 May 2010, 09:51:55 »
can you post a pic?
honestjohn
  • Kent
« Reply #4 on: 07 June 2010, 15:55:11 »
Would like to be able to.
Tried to post a pic but can't insert it (just comes up with img/img in square brackets) - asked admin for help a while ago and got no reply yet.
Anyone know if levels of authorisation exist for members and I do not yet have that access?
« Last Edit: 07 June 2010, 16:05:05 by honestjohn »
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 07 June 2010, 16:12:14 »
have look here about posting photo http://www.omegaowners.com/forum/YaBB.pl?num=1215723122 :y
honestjohn
  • Kent
« Reply #6 on: 08 June 2010, 08:23:59 »
Thank you for the link to the tutorial - I would not have got this far without it.
Here's the pic...
The red circle shows the empty connector.
The yellow circle shows the vac pipe connecting to what I believe is the air cutoff valve solenoid.
If I take the vac pipe off the solenoid and connect it to the empty connector I can hear a whirring sound which sounds like it should be doing something other than sitting there idle :-/
Any comments appreciated.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 08 June 2010, 08:37:16 »
The angled connector your talking about should have a piece of Vac Pipe about 4" long in it and it goes virtically down straight into another connector. If you have a look I am sure you will see where it should go mate :y
Hope that makes sense :D
« Last Edit: 08 June 2010, 08:38:29 by Loo-knee »
honestjohn
  • Kent
« Reply #8 on: 08 June 2010, 09:20:37 »
Yes, great I can now see where it should fit.
Anyone know what the description of the pipe is? Tried google/e-bay but can only find soft vac pipe with too large a diameter.
amba
  • Medway towns
    • German V6
« Reply #9 on: 08 June 2010, 09:26:30 »
Where abouts in Kent are you ? as I have a spare bit of vac pipe here....I am out and about most days so if you aren,t mobile I might be passing you in the week.
honestjohn
  • Kent
« Reply #10 on: 08 June 2010, 20:06:13 »
Many thanks for the offer Amba, it's very kind of you :y
I managed to cut a short length off another pipe which could spare the 7cm or so needed to connect it up.
All done now. Car runs no worse for it and is probably better that it's in place.
amba
  • Medway towns
    • German V6
« Reply #11 on: 08 June 2010, 20:12:26 »
Glad your all sorted now.Might see you about on my travels then.
honestjohn
  • Kent
« Reply #12 on: 09 June 2010, 17:38:25 »
pic disappeared so putting it back up in case anyone interested in future :)
« Last Edit: 09 June 2010, 17:40:05 by honestjohn »
