Author Topic: MOT fail on track rod  (Read 1325 times)
Osaze
  • Hants
« on: 09 June 2010, 16:57:13 »
"Nearside outer track rod end ball joint has excessive play"
I had the front lower wishbones replaced only last year  :o
How do I sort this one?
"I'm the Omega Man - always talking to myself" --The Police.
johny5
  • Portsmouth, Hampshire
Re: MOT fail on track rod
« Reply #1 on: 09 June 2010, 16:58:28 »
New track rod is easy to replace! its not part of the wishbone.
maximoke
  • Daventry/Northampton
« Reply #2 on: 09 June 2010, 18:23:29 »
Although you might have a problem getting it off the adjuster bar.  I need to do this on mine, and am considering getting the entire link i.e. inner and outer and adjuster bar in one package!
sport
  • Stoke on Trent
« Reply #3 on: 09 June 2010, 19:37:44 »
Yea get both just in case  the entire link i.e. inner and outer
took mine to garage took two days to get it off
« Reply #4 on: 09 June 2010, 19:45:24 »
Bad luck O - hope it isn't too bad to get off for the repair :y :y
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #5 on: 09 June 2010, 23:13:09 »
Not really too much of problem to separate the track rod end from the adjuster normally.
Take the whole arm off, clamp in a vice and heat the threaded point of connection, normally is easily separated then with a large stilson wrench.
Some people say that  you should not heat steering components, but I have seen all sorts of professionals do  this this as a routine operation and have done it myself several times with no ill effects.
« Reply #6 on: 10 June 2010, 08:39:45 »
Snap, all mine have been removed (front and rear) and had this treatment followed by a good clean of the threads, plenty of grease and a refit with further grease on them.
It makes the job of the alignment centre so much easier  :y
