Author Topic: Exhaust heat shield  (Read 1711 times)
splott
  • Bebington, The Wirral
  • Veccy with a Miggy engine..............
    • Vectra GSI 3.2 v6
Exhaust heat shield
« on: 12 June 2010, 17:24:05 »
Is there any easy way to stop the exhaust heat shield rattling?
Its driving me mad :'(
Thank you for reading this. I’ve officially wasted your time!
kev2b4
  • Luton, Beds
    • 2.5 CDX ,2.5 tourer
Re: Exhaust heat shield
« Reply #1 on: 12 June 2010, 18:49:41 »
I would imagine the retaining bolts are totally corroded in - so you can't undo without shearing them off - but if you did this depending on access drill out and re-tap with ST ST bolts and copper grease - it helps but doesn't stop things seizing in the heat -- ( tried it at work several years ago - plenty copper slip - take out 1 hour later - still tight - mind you did get to 600 deg C in the meantime!)
« Reply #2 on: 12 June 2010, 18:54:53 »
if its the ones at the front round the cats....bloody great stainless jubilee clips work well  :y
splott
    • Vectra GSI 3.2 v6
« Reply #3 on: 12 June 2010, 19:05:12 »
Don't fancy doing that :o :o
splott
    • Vectra GSI 3.2 v6
« Reply #4 on: 12 June 2010, 19:08:40 »
I think it is the cat shields on the drivers side :y, bloody annoying rattle.
I'll  try the jubilee clip stunt tomorrow
kev2b4
  • Luton, Beds
« Reply #5 on: 12 June 2010, 20:05:30 »
what ever  works!
splott
    • Vectra GSI 3.2 v6
« Reply #6 on: 12 June 2010, 21:45:49 »
what ever  works!
Didn't mean to be rude Kev2b4, just that I will put up with the rattle if it meant doing what you suggested :y
