Author Topic: Drivebelt Change Omega B/Catera: Best Shortcut  (Read 855 times)
TestOmega
  • Mississauga, Canada
  • Been helped, will help.
« on: 15 June 2010, 03:06:14 »
Any suggestion to change the serpentine/drivebelt auxillary without getting under the engine on jacks would be much appreciated.  My alternator/generator bolts are so well seized I cannot get near these.
I believe it all revolves around looping the Air Injection cross-over pipe.
Regards.
!!!!!!!!!!!!!!!!!!  May I be blessed to give more than I receive  !!!!!!!!!!!!!!!!!!
Re: Drivebelt Change Omega B/Catera: Best Shortcut
« Reply #1 on: 15 June 2010, 06:01:00 »
Regards.
Top left pulley, as you stand infront of the car, is the belt tensioner. 15mm spanner/wrench on it and lever to the right will remove the tension from the belt to remove it. You're right about the air injection pipe. Lower right is a 6mm nut you've to remove to allow you to reomve the belt from behind it & feed the new in. It might be easier to remove all the 'bagpipes' so you can see what you're doing.  :y
« Reply #2 on: 15 June 2010, 08:22:11 »
As above - the small 6mm torx bolt is a bit difficult to get to and really awkward to refit.  15-20 minutes should see it done though :y
TestOmega
« Reply #3 on: 16 June 2010, 03:46:05 »
Thank you I could not avoid getting under the car it was too tight from above.  Once I took the plastic under carriage shield off the view was wonderful.  Much easier to change from there on.
Regards. :y
« Last Edit: 16 June 2010, 03:46:38 by TestOmega »
