Author Topic: V6 not starting help!!  (Read 3146 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 21 June 2010, 08:39:53 »
Got to go to work this morning and will not start!turns over fine but won't start.paperclip done and got 19 and 135 any suggestions of how to fix??
scream if you want to go faster!!!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: V6 not starting help!!
« Reply #1 on: 21 June 2010, 08:46:52 »
crank sensor is 19 and 135 is engine control module,I would fit a new crank sensor and try it
other rides
mr ICE man
  • dolgellau wales
« Reply #2 on: 21 June 2010, 08:51:31 »
thought so!never had this before!do i get from vx or pattern part and how much are they?plus i live miles from a vx dealer!!
« Reply #3 on: 21 June 2010, 08:52:16 »
VX definately.
Pm andyc....he will have one in stock and does tradeclub by post  :y
it will be the crank sensor causing it  :y
mr ICE man
  • dolgellau wales
« Reply #4 on: 21 June 2010, 08:57:30 »
cheers guys!!pm sent!!
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 21 June 2010, 09:42:12 »
Sounds like Crank Sensor Iceman, get it from Vauxhall mate save yourself stress :y
mr ICE man
  • dolgellau wales
« Reply #6 on: 21 June 2010, 10:23:48 »
ok had a ferkle and found the sensor with part no 1928403429 and called vx there are 2 sensors one with a wire going to it and one without not sure what he means!!can anyone help?the sensor without the wire is 2 week to 3 month wait as its a non stock part!!!
mr ICE man
  • dolgellau wales
« Reply #7 on: 21 June 2010, 10:27:19 »
am looking at the correct part??just a thought!part im looking at is behind the injecter connecter and has 3 wires going to a connecter,thats all ive looked at so far,do i need to get to the other on the block to see??
« Reply #8 on: 21 June 2010, 10:38:04 »
Crankshaft sensor for 2.5 V6 is either:
90492061 - Jack Plug has rounded corners
90492006 - Plug has square ends
These part numbers relate to vehicles built between 1994 to 2003 with engine code X25XE
I've never heard of a Omega crank sensor without a wire lead????? but I have heard of VX Dealers who don't know their Ar*e from their Elbow!!  ;D ;D
HTH  :y
The above most definately DOES NOT apply to Andyc!!! :y
« Last Edit: 21 June 2010, 10:40:59 by philrich1064 »
mr ICE man
  • dolgellau wales
« Reply #9 on: 21 June 2010, 11:01:17 »
Which end is that?and where is the part no just to be sure!
« Reply #10 on: 21 June 2010, 11:05:59 »
C/S connector just in front of lifting bracket 3rd pic down http://www.omegaowners.com/forum/YaBB.pl?num=1181719948
« Last Edit: 21 June 2010, 11:08:40 by RobG »
mr ICE man
  • dolgellau wales
« Reply #11 on: 21 June 2010, 11:24:12 »
Sweet!I'm lookin at the correct thing!where is the part number?
« Reply #12 on: 21 June 2010, 11:31:03 »
Check the shape of connector then refer to Phils post above for correct part#
mr ICE man
  • dolgellau wales
« Reply #13 on: 21 June 2010, 12:25:29 »
part that goes into the engine by oil filter has rounded corners and has 90432061 on it ant the top connecter has 3 wires and has 1928403429 on it hope that helps!!
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #14 on: 21 June 2010, 14:16:01 »
Ok, look at the connector which will be at the back of the passenger side head. If it has Radius Corners they call it Oval. (this is the one I think will be on your car)
If it has Square corners as for a Rectangle one.
Hope that makes sense, I will see if I hae a picture to explain better what I mean :y
