Author Topic: need help please....  (Read 1567 times)
Rich p
  • nottingham
« on: 23 June 2010, 00:52:47 »
i brought my car with a few minor fault's (only expected as it's done 213k miles) but the one that is doing my head in is the throttle possition sensor low voltage fault i cant seem to get around....the car is a facelift W reg 2.2 estate with lpg and i have replaced the following
throttle pedal
throttle body
cleaned out all breather's and fitted the breather box on the back of the rocker cover
i have also changed the ECU in the fuse box with a new key and black box under the steering column but the car then refused to start...
i have been informed that the lpg kit is fitted and a wire is conected to the throttle possition sensor somewhere but i dare not start looking into the wireing as there are load's in there.....
i am really wanting i suppose is someone who know's about lpg kit's and can point me in the right kind of direction to get it fixed without a mega expense
thanks in advance
Rich
2.2 on lpg and loving it
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: need help please....
« Reply #1 on: 23 June 2010, 01:36:46 »
is there any other codes coming up????
new ecu has it been setup for alarm and imobiliser & ABS
have you checked all the earths in engine bay.
« Last Edit: 23 June 2010, 01:45:19 by Russ76 »
davethediver
  • Blackburn, Lancs.
« Reply #2 on: 23 June 2010, 12:11:06 »
Manual or Auto?
Could well be MAF sensor as this has been known to throw up the TPS fault P1555 i think  :-?
P.A. Caron de Beaumarchais
« Reply #3 on: 23 June 2010, 13:12:56 »
Yep, and check the brake pedal switch
Rich p
  • nottingham
« Reply #4 on: 23 June 2010, 14:42:02 »
both "My Naff Code Reader" and tech 2 have come up with throtle possition sensor low voltage, i have checked all earth's in the engine bay and they all seem ok to me..
will check the brake pedal switch and also the maf sensor
i forgot to say it's a manual and the car with spanner light is oin the dash and it wont rev over 4.5k rev's..
thaks so far for the advice..finger's crossed i can get it sorted out soon
« Last Edit: 23 June 2010, 14:42:56 by Rich_p »
« Reply #5 on: 23 June 2010, 15:20:57 »
Classic symtons of cam sensor failing, which will also throw spurious codes P1555 being one of them
Rich p
  • nottingham
« Reply #6 on: 23 June 2010, 15:55:48 »
cam sensor was changed straight away for a genuine new gm one...will see if i can get the actual code that was there from the tech2 guy
« Last Edit: 23 June 2010, 15:56:11 by Rich_p »
« Reply #7 on: 23 June 2010, 17:03:21 »
All connections OK. As said revving @ 4.5K max is cam sensor
Rich p
  • nottingham
« Reply #8 on: 23 June 2010, 17:23:21 »
yes mate all conections are very good and still it wont rev over 4.5k..... :(
