Author Topic: Coolant Level Sensor  (Read 1253 times)
twiglet
  • Norwich, Norfolk
« on: 30 June 2010, 18:27:09 »
As mentioned in a previous post, the check control is throwing up a coolant level warning on startup, even if the coolant level is correct.
I've been told that this means the sensor is knackered, and the only remedy is to replace the whole header tank.
Does anyone know if this can be fixed?
Failing that, does anyone have a replacement header tank going spare? My tank is really clean, so is there anyway of swapping the level sensor over?
Cheers
Re: Coolant Level Sensor
« Reply #1 on: 30 June 2010, 18:30:41 »
they can occasionally be removed, but not officially.
more break than come out in one piece.
You can short the sensor to get rid of the warning, but obviously no longer have the alert function.
new tanks about £30 iirc
« Reply #2 on: 30 June 2010, 18:30:59 »
I think Jaime (theboy) has managed to swap the sensor but a new bottle is only about £30 ;)
twiglet
  • Norwich, Norfolk
« Reply #3 on: 30 June 2010, 18:36:46 »
Cheap at half the price! Bargain!
Sounds like I'm gonna become very good friends with my local Vauxhall parts dept!
How do you guys get on getting bits at trade price from them?
« Reply #4 on: 30 June 2010, 18:42:09 »
Join Autobahn Stormers, its cost £20 and you'll receive a trade card with will save you a fortune on service parts ;)
twiglet
  • Norwich, Norfolk
« Reply #5 on: 30 June 2010, 21:03:07 »
Excellent! I was gonna do that tonight anyway!
Anyone know if its too late to get on the ABS stand at Billing?
« Reply #6 on: 01 July 2010, 11:18:39 »
twiglet, before doing anything else.... pull off the metal sprung clip fastening the bottle to the car & push the bottle towards the engine by about 25mm to free it from its fixing points, then have a look underneath the bottle to check the sensor plug has not just worked itself loose! I had the self same issue & it was the plug not a faulty sensor. HTH  :y
twiglet
  • Norwich, Norfolk
« Reply #7 on: 01 July 2010, 17:47:14 »
Cheers, I'll have a look.
Just to confirm thou, the warning comes up at startup only.  It says 'coolant level' and then underneath it says 'ok'.
Is this definately a failure, or is it just a system check?
It goes away if you acknowledge it and doesn't return until the next time you startup.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #8 on: 01 July 2010, 19:26:18 »
I've found that being politely cheeky helps when ordering parts at the Dealers, I tell them I prefer to use their parts for the quality but can't justify the expense and then ask them if they can give me a discount... they always do.
