Pages: [1] 2 3  All   Go Down
Author Topic: Auto box again  (Read 4057 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Auto box again
« on: 25 June 2010, 20:01:05 »
Some of you may remember I had to fit a new auto box last year. My AR25 messed up and I swapped it for an AR35. Thanks for your help once again over that.
Guess what the AR35 has started to do  ;D ;D
Hanging in second, thumping into third and then limping. Borrocks!!!
It started off this week with a mild thud going into third and has got progressively worse. It is a lot worse when the box gets really hot. The recent hot days have really shown it up whilst running my parents around Lincoln. It seems better when the box is not so hot  :-/
To make matters worse, I start a new job on Monday. First permanent work in two years.
I have checked the ATF level (engine running through the gears etc) and the level is okay BUT the fluid is brown and smelly. Yet, it has only been in a year  :-/ :-/
Any ideas before I go mad with frustration  :y :y :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
Re: Auto box again
« Reply #1 on: 25 June 2010, 20:31:06 »
Might be but hope it isn't the thrust washer. If it is then the bits will be in the sump. Also don't like the sound of the fluid being brown and smelly. How many miles since you replaced it?
However someone with more knowledge will no doubt be along shortly.
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #2 on: 25 June 2010, 20:41:49 »
The box had a new thrust washer fitted last year, in place of the silly plastic GM one. Sorry forgot about it  :-[
Its done about 7000 miles since last Jan when it went in  :y
Re: Auto box again
« Reply #3 on: 25 June 2010, 21:03:24 »
Sounds like 2-3 solenoid. Was the box & T/C thoroughly flushed before adding new ATF
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #4 on: 25 June 2010, 21:05:48 »
The whole lot was flushed, even the cooler at the front.
This solenoid chappy. What does it involve to remedy it?
Re: Auto box again
« Reply #5 on: 25 June 2010, 21:22:47 »
Sump off jobbie. Have a read of this and note "Figure 2" part #307 http://images.omegaowners.com/downloads/Autobox_Docs/4L30E_Article.pdf
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #6 on: 25 June 2010, 21:34:39 »
Thanks Rob. I have had the sumps off before, so am okay there  :y
With the sumps off are they obvious and easily accessible?
Of course the big question....where on earth do I get them from and what sort of cost are they?
Re: Auto box again
« Reply #7 on: 25 June 2010, 21:37:54 »
Yes to obviousness and accessibility. Pricewise, couple of years back, about £80 or thereabouts. Nowadays, no idea. Maybe one of the breakers got an old box lying around for cannibalising
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #8 on: 25 June 2010, 21:38:54 »
as you aint a million miles away, if you need a solenoid ive got two u/s boxes here, solenoids should be o,k though :y
Re: Auto box again
« Reply #9 on: 25 June 2010, 21:40:15 »
Was just about to post to tell OP to give you a PM ;D ;D
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #10 on: 25 June 2010, 21:42:21 »
thanks rob, nothing like being known for blowing up g/boxes is there ;D ;D ;D
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #11 on: 25 June 2010, 21:56:05 »
The stupid thing is, I took my old AR25 to the scrap yard in March  >:(
Tonka.
    • 2000 2.5 CDX
Re: Auto box again
« Reply #12 on: 25 June 2010, 21:59:44 »
Thanks alf. Would you be able to help me out with the job?
unlucky alf
  • worksop, notts
Re: Auto box again
« Reply #13 on: 25 June 2010, 22:01:20 »
well i had 3 busted ones but some thieving git knicked one while i was on holiday, it still had the selector switch on it otherwise i wouldnt have been so peed off >:(
anyhow let me know if you need anything & i`ll strip down one of the others. :y
« Last Edit: 25 June 2010, 22:02:28 by froggy »
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: Auto box again
« Reply #14 on: 25 June 2010, 22:08:01 »
When did you last change crank sensor?
Pages: [1] 2 3  All   Go Up
