Author Topic: fault code 0430  (Read 1191 times)
Rayviator
  • Cardiff
fault code 0430
« on: 04 July 2010, 20:54:18 »
hey, i have have fault code 0430 showing up and found out its the o2 sensors, are these easy to change or best left to a garage, i have a 2001 3.2 v6 est
i tried halfords but no haynes manual for it
Re: fault code 0430
« Reply #1 on: 04 July 2010, 20:55:54 »
Its not actually the O2 sensor at fault....its just reporting it.
The fix is to either replace the precat, or move the o2 sensor to the other side of the cat, see the maint guide section.
most 2.6 and 3.2's suffer this as they get older.
Rayviator
  • Cardiff
Re: fault code 0430
« Reply #2 on: 04 July 2010, 20:59:16 »
ok, whats a pre cat? are they cheap, i drive all around europe so have no qualms about buying new bits as long as it works
Re: fault code 0430
« Reply #3 on: 04 July 2010, 21:01:50 »
they WONT be cheap....
http://www.omegaowners.com/forum/YaBB.pl?num=1253462747
shows the alternative.
Re: fault code 0430
« Reply #4 on: 05 July 2010, 12:16:21 »
really would not worry too much,with the age of these cars now most 3.2 and 2.6 have that code. Just move the 2nd o2 sensor behind the main cat when you bump into a friendly welder, as the guide.  :y
Re: fault code 0430
« Reply #5 on: 05 July 2010, 17:04:55 »
Buy a code resetter and turn the light off. Mine only comes on twice a year ... 3 days after getting to France... 3 days after getting back home ...
I'm convinced it has something to do with the different ratio's of propane/butane in UK/French LPG. On changing, the system sees a "difference" which it flags as a fault.
Probably wrong, but its my experience and my theory !!!
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: fault code 0430
« Reply #6 on: 05 July 2010, 22:39:38 »
Yes I'm with Entwood on this one - cheap code reader to reset once or twice a year.
