Author Topic: steering adjust  (Read 1326 times)
geoff
  • thornaby,stockton on tees
steering adjust
« on: 14 July 2010, 07:49:16 »
can anbody tell me if i can adjust play in steering rack please  :y :y :y
Re: steering adjust
« Reply #1 on: 14 July 2010, 07:59:02 »
there is steering box, not rack.
and a little play can be removed....but ill let someone else explain the details.
geoff
Re: steering adjust
« Reply #2 on: 14 July 2010, 08:36:21 »
ok i meant box just use to saying rack lol :-X :-X :-X :-X :y :y :y :y
Kaycee
  • Doncaster
Re: steering adjust
« Reply #3 on: 14 July 2010, 08:50:01 »
Yes it can be done there is a torx screw locked with a nut on the top of the ST box make sure the steering wheel is absolutely in the Straight ahead Position do not under any circumstances have the engine running while adjusting undo the nut whilst holding the torx screw and gently with not much more than the weight of yr fingers move the wrench ie tighten those allen key types are the best it wont move much and retighten and check by going for run  if you inadvertantly tighten too much yu will feel a definite drag on the steering wheel so it must be backed of but trial and error will soon get it right BUT DONT tighten too much
hth
robert
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Re: steering adjust
« Reply #4 on: 14 July 2010, 09:23:41 »
Read this http://www.omegaowners.com/forum/YaBB.pl?num=1268642813 :y
geoff
Re: steering adjust
« Reply #5 on: 14 July 2010, 10:01:50 »
cheers guys have done now very pleased steering feels more responsive when turning left to right  :y :y :y :y
