Author Topic: Keyfob not working...HELP!!!  (Read 2252 times)
Lesopc
  • West London
  • Worlds Biggest GM Fan
« on: 13 July 2010, 12:10:58 »
I have just had my 2 feyfobs repaired and one of them is still not working. It's Red LED flashes which must mean the battery is good but it will not open/lock the car. I was told that the fob may need to be re-syncronised by putting it in the ignition and switching it on and the pressing the button about 2-3 times (which should lock/unlock the central locking). I tried this method 3 times over this morning and sadly it still does not operate as it should. Could there be any other reasons for this? All three microswitches click like new.
Why oh why was there never a V8 Omega????
Such a missed oppurtunity.
Look forward to the Cadillac ATS & ATS-V. Maybe a re-badged one will replace the Miggy as a RWD runner?
Re: Keyfob not working...HELP!!!
« Reply #1 on: 13 July 2010, 12:40:38 »
has that one ever worked with the car?
« Reply #2 on: 13 July 2010, 13:23:06 »
one of the keys that came with my Astra shed does similar. The led lights up every time but when shown to a transmitter tester doesn't actually produce a signal.
Martin_1962
« Reply #3 on: 13 July 2010, 14:42:47 »
It does broadcast, but the battery holder was off.
It has a refitted battery holder, 3 new switches, and it did broadcast on 433 920 as it should.
I assumed all it would need is resyncing, however I now get the feeling it will need to be recoded to the car.
ejr1039
  • Newport Pagnell
« Reply #4 on: 13 July 2010, 14:43:26 »
Try Turning ignition on but don't start the car, turn it off and remove the key and hold it near the sensor near the interior light ane press the button for a few seconds.
« Reply #5 on: 13 July 2010, 14:46:30 »
this method is for the old  infrared type  ;)
Martin_1962
« Reply #6 on: 13 July 2010, 21:08:49 »
Any more ideas for Les?
They were both broadcasting and both refurbished, so SHOULD be OK.
One does work, for the other we can try.
1) Resync again.
2) Remove refit battery and try resync.
3) Ask an auto locksmith to match to the car.
4) Visit an OOF Tech II to match to car.
Finally did both work the car previously?
« Reply #7 on: 13 July 2010, 21:13:30 »
From the OP ... "one of them still not working" .. I'm guessing it might never have worked ... probably needs a chat with a Tech2.. :(
« Last Edit: 13 July 2010, 21:13:53 by entwood »
Martin_1962
« Reply #8 on: 13 July 2010, 21:15:26 »
They will - they are brand new heavy duty 4.5 Newton ones.
As Entwood says - I think one has never worked with the car.
« Reply #9 on: 13 July 2010, 21:25:40 »
Is the transponder microchip still attached correctly inside the key? It may have fallen out when the OP refitted his key blade??:-?
« Reply #10 on: 13 July 2010, 21:29:46 »
Not relevent for this particular issue - transponder only used for immobiliser...
Lesopc
  • West London
« Reply #11 on: 14 July 2010, 00:44:15 »
Keyfob has not worked since i became owner due to being already broken (microswitches). Thank you all for your advice.
Lush
  • King's Lynn
« Reply #12 on: 14 July 2010, 12:26:08 »
Got the same problem,tried everything including checking for lose wires etc,great job done by Martin,can fully recommend.
As above the keys used to work,but now zilch!
Even when pushing the drivers door knob down does not lock off the rest of car,getting really frustrated............Grrrrrrrr :'(
« Reply #13 on: 14 July 2010, 12:34:07 »
Nowt to do with the key then ...  either the contact in the drivers door servo motor or the central locking control unit.
Check the control unit has not come unplugged ..
Removal
2 Remove the trim panel from the right-hand
front footwell.
3 Release the catch and disconnect the
wiring from the bottom of the control unit.
4 Unscrew the mounting nuts and remove the
control unit from the vehicle.
Refitting
5 Refitting is a reversal of removal, but tighten
the mounting nuts securely.
and check the wires as they go from the body through the door ... not unheard of to chafe and suffer damage .. :(
Martin_1962
« Reply #14 on: 14 July 2010, 13:02:21 »
I am monitoring this thread.
I have had 2 or 3 failures total since I started repairing.
One was a huge chunk of missing PCB.
I have had to reflow the main chips quite regularly.
One similar to Les and Pauls problem was as follows.
Broken for long time fob, I had to basically rebuild with battery holder and switches.
Sent it back, resync failed.
They went to an auto locksmith and they re-paired it to the car.
If there are any actual faults with the repair I will reimburse.
All of the fobs in this thread left me with broadcasting signal.
Could it be to do with fob being unpowered for a few months?
