Author Topic: Camber Tools  (Read 2839 times)
Shrek
  • Fife , Scotland
Camber Tools
« on: 17 July 2010, 09:12:03 »
Hopefully doing my wishbones soon with Lemforder's and was looking at these tools to help , so do you think these will be any good ??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400131773810&ssPageName=STRK:MEWAX:IT
And
http://www.lmfvauxhall.co.uk/store/product.php?productid=16680&cat=0&page=1
Any thoughts  :y
"My Naff Code Reader" and OBD2 readers available .
blue_dream
  • Wellingborough
Re: Camber Tools
« Reply #1 on: 17 July 2010, 09:50:55 »
 Hi
    I would not bother with these, just have the front wheel aligment checked after, i have the track rite camber gauge which is good, i used when i replaced the front struts as you lose the settings, ok to get the setting about right, you need to make sure you have the right gauge as i believe their are two different types, then you MUST have the whole wheel aligement checked by a system called the HUNTER system, have a look on here with a company called wheels in motion.  :) :)
psnimv6
  • tyrone n ireland
Re: Camber Tools
« Reply #2 on: 17 July 2010, 10:18:20 »
i seen the same thing on tv a few months ago and i think the magnet on disc thing would be very useful to get back to the correct setting that you had before suspension work ,i don,t think it would be any good to set the car up to the right setting totally because the suspension needs to be under load to get correct but it wouk be useful to get back to what it was after some work i think
Shrek
  • Fife , Scotland
Re: Camber Tools
« Reply #3 on: 17 July 2010, 10:27:01 »
Hi
WIM is to far away from me  :y
Shrek
  • Fife , Scotland
Re: Camber Tools
« Reply #4 on: 17 July 2010, 10:29:24 »
I know it needs done under load but with some playing around it should at least be better than nothing .... ie wieght on wheels then check and jack up and re adjust and re-check etc ... :-/   Im not showing any inner tyre wear just now so if i can get it back to what it is just now then i would be happy  :y
« Last Edit: 17 July 2010, 10:31:03 by Shrek »
Re: Camber Tools
« Reply #5 on: 17 July 2010, 10:51:13 »
I wouldn't bother with either. You can set camber up reasonably accurately with a spirit level on a flat surface. The magnetic tools are rubbish.
.. and you don't need camber adjusting bolts because it's already adjustable. :y
Re: Camber Tools
« Reply #6 on: 17 July 2010, 10:53:41 »
You can replicate the original setting quite easily.
Before dismantling
Measure with a spirit level, and or
Place both sides on stands.
Using the approprite sized socket as a feeler gauge measure the gap from vertical face of the wheel rim to shock body.
Do the work.
Set camber with same socket trapped between shock and rim. Key to it is setting the correct tension
on hub bolts so it can move but not slip when you let go.
Hth
Re: Camber Tools
« Reply #7 on: 17 July 2010, 10:57:31 »
Before dismantling
Do the work.
Hth
This will get it close but the problem is if the wishbones are a slightly different length or it was previously adjusted with saggy bushes it will still be wrong.
You'll also end up with the toe being out after a wishbone change and that's less easy to DIY and more critical for tyre wear so the car would need a proper setup anyway, IMHO. All we're going to be able to do is get it to a state where it won't scrub 10k miles of tread off the tyre on the way.
Re: Camber Tools
« Reply #8 on: 17 July 2010, 11:12:35 »
Before dismantling
Do the work.
Hth
Totally agree. Should have said it must still be checked fully after.
Have used the socket method when changing shocks, wim said they could not improve the settings which they originally set. Shock change different story to wishbone change though, all you can do is get it best you can before driving the car directly to a set up firm.
Toe I find it worth looking very carefully along the side of the car and ."rifle site" the edged of the front wheel for alignment with the rear wheel edge. But this needs doing on one side before staring work on other wishbone or it's a mare, involves a lot of reversing back and forth to get the tyre contact patch settled between adjustments. Very difficult with semi seized track rod adjustors as well.
Anyway, main thing is to attempt the correct setting best you can, don't just throw it back together and drive it without set up.
hoofing it
Re: Camber Tools
« Reply #9 on: 17 July 2010, 11:22:16 »
Hi
[/highlight]
theres a chap in Edinburghwho does the 4 wheel tracking as far as I know he does tracking on top end cars.
I will try and get a Phone number for him from my mate :y
Shrek
  • Fife , Scotland
Re: Camber Tools
« Reply #10 on: 17 July 2010, 11:34:30 »
Hi
[/highlight]
Thanks that would be great  :y
Shrek
  • Fife , Scotland
Re: Camber Tools
« Reply #11 on: 17 July 2010, 15:21:40 »
Before dismantling
Do the work.
Hth
Oh why do these car has to be so awkward  ::) ::)
  • Auckland
    • Mazda MPV
Re: Camber Tools
« Reply #12 on: 17 July 2010, 16:20:52 »
I had a good look at my front tyres last weekend and realised that they were scrap due to scrubbing on the inside edges.  >:(
I have ordered Lemforder wishbones from Allgerman and went and got some cheap tyres fitted this morning.
None of the local garages or tyre fitters I have spoken to have any experience of setting the camber  :( so I think I will have to check and/or set it myself after I have fitted the new wishbones.
My car has 17" rims so I have calculated that the top edge of the rim should be 8.8mm nearer to the centre line of the car than the bottom edge
17" x 25.4mm x sine(1'10") = 8.8mm
does the maths look correct?
Re: Camber Tools
« Reply #13 on: 17 July 2010, 16:36:19 »
Hi
This place is nearer ;) and uses the Hunter system http://www.starperformance.co.uk/wheelalign.htm
Kaycee
  • Doncaster
Re: Camber Tools
« Reply #14 on: 17 July 2010, 17:49:43 »
8.8 is spot on for -1.10
3mm at rims difference is approx 23 minutes according to my calculations i have mine set on level road to 9 mm and is -1-10  camber and running absolutely spot on
 its a relativley easy operation to do by the way
There is a tide in the affairs of man if taken at the flood will lead on to greater things
