Author Topic: my omega 2.5 td stops when he wants  (Read 2318 times)
pimpo
« on: 30 June 2010, 21:36:59 »
When i turn on my car it seems to work perfect, but after some time the engine goes down and if i donīt touch the trottle stops in one or two minutes, and at the moment if i touch the trottle. When the engine is hot ot park in the sun it get worse and only works for 50 meters.
It only works again if i swicht off the key an wait one minute or more.
Any ideas?
Re: my omega 2.5 td stops when he wants
« Reply #1 on: 30 June 2010, 23:38:32 »
Try the paperclip test ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 01 July 2010, 00:30:17 »
Just a shot in the dark here, check your battery / running voltage, you may have a stuck relay for your heater plugs (intermittently on), had this one before when turning corners.
Chris     :y
« Last Edit: 01 July 2010, 00:32:11 by zirk »
hoofing it
« Reply #3 on: 01 July 2010, 12:14:05 »
Add your location someone close buy could have a look :y
also try this
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
pimpo
« Reply #4 on: 01 July 2010, 13:56:05 »
i have made the paperclip test, and numbers 54 and 92 errors are show.
what piece is the fuelcutoff solenoid?
and my car doesnīt have cruise control, so why 92 error appear?
hoofing it
« Reply #5 on: 01 July 2010, 14:44:57 »
The fuel stop solenoid is at the back of the pump it has a single wire attached and is held on by a 8 or 10mm nut.
If you take the wire off first you should see a dome shapped bit this unscrews I think its a 24mm socket you need.
this is the solenoid ive got a spare if you need it :y
I'll try and post some photos later tonight :y
ignore 92 if you don't have cruise.
if you want cruise just replace the stalk and away you go.
Before you go taking things appart just check the small wire going to the solenoid it might be broken
« Last Edit: 01 July 2010, 15:14:23 by hoof »
hoofing it
« Reply #6 on: 01 July 2010, 21:00:31 »
heres a photo of the solenoid
« Reply #7 on: 01 July 2010, 21:09:11 »
also try this
He's in Spain Hoof :y
Omegatoy
  • UK
« Reply #8 on: 01 July 2010, 21:14:25 »
also try this
and its a big place!!!!! if near malaga then i could look at it but not any further!!! :y
hoofing it
« Reply #9 on: 01 July 2010, 21:31:16 »
also try this
ok cheers chaps :y ive got a spare if he's willing to pay p+p it doesn't weigh much :y
doh just noticed the opel omega b ;D ;D
« Last Edit: 01 July 2010, 21:33:55 by hoof »
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #10 on: 01 July 2010, 22:54:03 »
Pimpo.  What year is your Omega?
pimpo
« Reply #11 on: 02 July 2010, 19:34:28 »
I have test again the car with an "My Naff Code Reader" tester and i have erased the errors. the case is that the car is still not working and the errors donīt appear again.
tomorrow we will replace the fuel cut off solenoid, my mecanic had one.
Someone ask the year of my car, is from 1995.
 Why the fault codes donīt get saved again after erase them if the car is still not working?
pimpo
« Reply #12 on: 19 July 2010, 14:18:14 »
I have change the fuel cutoff solenoid and the car runs now perfect.
thanks
Omegatoy
  • UK
« Reply #13 on: 19 July 2010, 20:30:02 »
thats great Pimpo :y
