Author Topic: mot guy blown v6  (Read 3598 times)
terry
  • Dorset
mot guy blown v6
« on: 22 July 2010, 07:02:53 »
I am so gutted , i have just finished a top end rebuild (25v6). on account of high emissions.   All gaskets, valve steam seals, valves reseated, heads cleaned like like new, breathing imaculately clean, done 116k bores show not even slight wear, plugs, leads, the absolute full monty methodicly carried out, plus cambelt, rollers,tensioner ect, aux belt. oil, all filters,  started at first turn of key, all lamps on dash as normal, em light normal opp, up to temp, fans operate normaly, no issues at all so really happy , ran it for five days.  And then took it for MOT and left it already with temp at normal, when i went to collect it the guy told me he had to abort the emmision test because the temp gauge was off the scale fans didnt run and it was pumping out blue smoke like hell, now i have intermitant oil pressure and rattles to die for, i suspect this guy has been red lining it to heat up the cats and blown it, guys i could cry im so gutted, i had no recourse with the guy as i was not present and there where two of them working on it, apart from that it needed a new tyre, comments appreciated plus has any one got a half decent spare lump and a box of tissues
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: mot guy blown v6
« Reply #1 on: 22 July 2010, 09:20:09 »
did you make a note of the milage when you dropped it off,could be that they ragged it around the block
other rides
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 22 July 2010, 09:26:00 »
Sorry to here about this mate  :'(
But would imagine this will be hard one to prove :-?
Suppose they will blame you :(
Abiton
« Reply #3 on: 22 July 2010, 09:29:22 »
Failed water pump?
Big sympathy BTW.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #4 on: 22 July 2010, 09:35:52 »
Thats not good. My M.O.T. tester lets you stay with the car, any problems with the test and he points out the issue and lets you have a good luck at what he has seen.
Hope you sort it quickly and cheaply... speaking of which.
...has any one got a half decent spare lump and a box of tissues
I have a 3.0 Mv6 engine here...
http://www.omegaowners.com/forum/YaBB.pl?num=1278960807
« Reply #5 on: 22 July 2010, 09:46:30 »
this car was working until mot , right?
you need to talk to a lawyer I think..
omegadan67
  • northampton
« Reply #6 on: 22 July 2010, 09:58:12 »
if you ran it for 5 days and could prove all was ok and woking fine you may well have a case. by the way how far do you live from the mot place? might seem a silly question but if it drove ok to the test centre then you are not at fault
A little infomation is dangerous in the wrong hands
« Reply #7 on: 22 July 2010, 10:11:36 »
I can share in this, 5 miles after doing new heads, the new cambelt kit let go destroying a weekends work.
It may just be one of those things, but sounds like the car could have been turned off sooner  :-/
« Reply #8 on: 22 July 2010, 10:25:54 »
I always watch an MOT now. Ever since I took a car for MOT with an engine that had done 12 miles from a complete (rebore, pistons, rings, bearings, etc) rebuild, informed them that I wanted the minimum of idling to perform the emissions test only (power steering and brake servo not fitted) and to watch the gauges as it's not impossible that there's an air lock in the cooling system or other "bedding in" issues... only to find on my return that they'd left it idling unattended for an hour. >:(
terry
  • Dorset
« Reply #9 on: 22 July 2010, 10:58:48 »
car ran fine for five days, no issues atall, ive been around engines since i was i kid not much i cant handle for example i changed my cambelt without all the locking tool stuff, its easy if you set rollers and tensioner up correctly to start with, it comes out spot on first time long as you check and double check , took half hour to set up, rotate, check, rotate , check again no problem............ milage was the same as when i left it. mine was the last one of the day ,i suspect they reved it to max to heat up cats, the car had no sign of any smoke from exaust in five days, thanks for your comments guys
« Reply #10 on: 22 July 2010, 11:03:16 »
The fact that they let the temperature go off the scale tells me that they weren't watching it, or competent enough to spot the warming signs which must have been there (surely the coolant tank cap vented, for example). :(
What a nightmare. >:(
Hopefully you'll find another engine to drop in.
Cheers,
kevin
« Reply #11 on: 22 July 2010, 11:10:04 »
for example i changed my cambelt without all the locking tool stuff, its easy if you set rollers and tensioner up correctly to start with, it comes out spot on first time long as you check and double check , took half hour to set up, rotate, check, rotate , check again no problem............  ......
 :-?  :-X  :-X
« Reply #12 on: 22 July 2010, 11:12:01 »
Best you can do is put the ball back in thier court and ask them what they are going to do about it.
If they are a decent outfit than they may offer something, but at the point it seems you have nothing to lose and something to gain.
Thier reputation is at stake if word gets arround, especially if the local trade get to hear things. ::)
« Reply #13 on: 22 July 2010, 11:27:35 »
I am not even going to pass comment...
......Other than you are miss leading yourself
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #14 on: 22 July 2010, 11:32:11 »
tried it once, never again. always use locking kit now. :y
