Author Topic: 2.2 misfire and cutting out  (Read 1515 times)
acura
  • Lancashire
« on: 25 July 2010, 18:34:17 »
lo guys.
A long time since I've been on here, nice to be back.
My ex-meega, a 2002 2.2 CD auto now belongs to my lad and he's having a problem with it misfiring on occasions.
It seems to happen under very damp conditions only. On starting the car, sometimes reluctantly the engine seems to be firing on 3 pots or so and the emissions light (engine symbol not car and spanner) comes on. If the engine is turned off and re-started, maybe at the 3rd attempt the engine runs normally with no light.
We've plugged in a code reader but there are no codes stored. Strange I know but there you are.
Can anyone suggest any causes for this please?
Thanks in anticipation, Steve.
From Consul 375 to Omega, 30 cars and counting.....
Re: 2.2 misfire and cutting out
« Reply #1 on: 25 July 2010, 18:50:22 »
I suspect its water from the scuttle getting round the coil pack.
Pull the coil pack and look for evidence of water being presence
« Reply #2 on: 25 July 2010, 19:07:28 »
yup, the seal around the bottom of the wiper arm lets in water than can drip onto the engine, through the eco tech cover and into the plugs  :y
acura
  • Lancashire
« Reply #3 on: 25 July 2010, 19:21:50 »
Thanks to both of you guys, this makes perfect sense.
I guess the obvious remedy is to replace the wiper arms seals then.
Again, cheers for that.  :y
« Reply #4 on: 25 July 2010, 19:24:32 »
I believe the general fix for this is silicon sealant piped around the underside of the scuttle/wiper seal & centre joint on scuttle also? :y
« Reply #5 on: 25 July 2010, 19:26:45 »
Nothing wrong with motor, smear of silicon sealant around the base, where the scuttle meets the wiper arm   :y
« Last Edit: 25 July 2010, 19:26:58 by tunnie »
acura
  • Lancashire
« Reply #6 on: 25 July 2010, 19:42:42 »
Many thanks! :y
