Author Topic: Instantaneous consumption.  (Read 1624 times)
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
« on: 03 August 2010, 09:43:55 »
Morning all,
I remember reading a thread  about instantaneous consumption- 0.3 gallons per hour being correct.
Mine shows 0.4 gallons per hour-what causes this?
All the best
Steve
Previous
Omega 2.5 GLS Auto Estate         S115 JVV
Omega 3.0 Elite  Auto Estate        T639 TFA
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Re: Instantaneous consumption.
« Reply #1 on: 03 August 2010, 09:48:11 »
If my aircon is on it creeps up to 0.4 gph.
Usually sits at 0.3 gph  ;)
« Last Edit: 03 August 2010, 09:49:50 by Tonkapaj »
The happiest people don't have the best of everything,
they just make the best of everything they have.
tony2
  • peterlee north east
    • 2.6 cdx auto
« Reply #2 on: 03 August 2010, 10:15:53 »
mine on first start up runs at 0.4gph but once warmed up on 0.3gph ps mines a 2.6  tony2
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #3 on: 03 August 2010, 10:25:48 »
my 3.0  is 0.3 gph with aircon off or 0.4gph with it on  so sounds about right for the 3.0(i hope).
lee
GaryBC
  • Egham, Surrey
« Reply #4 on: 03 August 2010, 12:50:24 »
Knocking it into neutral or park when in traffic helps.
SeedyV6
« Reply #5 on: 03 August 2010, 13:00:19 »
Is your idle set correctly? Mine wasn't until recently (thanks Daz :y) and this was the cause of mine being way over the top  ;)
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
« Reply #6 on: 03 August 2010, 13:15:10 »
Thanks-seems about right then.
All the best
Steve
Previous
davethediver
  • Blackburn, Lancs.
« Reply #7 on: 03 August 2010, 13:16:53 »
Its not so much a case of 'setting the idle' more of a making sure its well serviced, breathers cleaned, filters clean, timing set up right.
As with any car if its not looked after and well serviced fuel consumption will be poor. But 0.4 is nothing to worry about IMO :y
P.A. Caron de Beaumarchais
mathewst
  • Split, Croatia
    • v40
« Reply #8 on: 03 August 2010, 16:00:12 »
Ii is a little bit to wory about cause it usually means the car is running rich on fuel ( higher consumption)
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
« Reply #9 on: 03 August 2010, 18:29:10 »
Thanks-if it is running rich-whats the cure?
Previous
SeedyV6
« Reply #10 on: 03 August 2010, 19:41:41 »
I agree, but mine had been serviced, clean breathers and filters and the timing was ok. But some monkey had tinkered with the idle and it needed adjustment.
