Author Topic: Fuel flap, is it meant to lock?  (Read 1167 times)
stevo61r
  • West Midlands
« on: 06 August 2010, 19:46:49 »
Is the fuel flap meant to lock when you lock the car?
It has been like this since I've had the car. :-?
Re: Fuel flap, is it meant to lock?
« Reply #1 on: 06 August 2010, 19:48:18 »
Yes
« Reply #2 on: 06 August 2010, 19:51:40 »
You mean it's been locked since you got the car? Probably the motor goosed. To open it, you can access the locking bolt/pin from inside the boot/rear off side wing.  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 06 August 2010, 19:52:50 »
check for 12 volts at the solinoid when you lock the doors  :y
easy to change if knack*rd by removing the trim panel behind it
i've got a spare one here if you need it
pm me  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 06 August 2010, 19:53:48 »
must type faster  ;D ;D
stevo61r
  • West Midlands
« Reply #5 on: 06 August 2010, 20:14:39 »
It never locks.
Might be something stupid? I'll check behind the trim.
