Author Topic: Jack on diff  (Read 2533 times)
Dave Elite
  • Ellesmere Port
Jack on diff
« on: 31 August 2010, 23:12:35 »
Is it ok to jack the back end up on the diff?
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Jack on diff
« Reply #1 on: 01 September 2010, 06:45:31 »
Someone here once said it's not ok because the diff is basically hanging "free" inder the car (rubber bushings)
However, I have done that once or twice and made no visible damage  :-/
Re: Jack on diff
« Reply #2 on: 01 September 2010, 08:11:49 »
No as you risk (at the least) damaging the rubber mounts that bolt to the diff.
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Jack on diff
« Reply #3 on: 01 September 2010, 08:24:12 »
And one thing I forgot: the diff is not a steel casting (aluminium or some other light alloy?) and therefore there is a big risk that you may crack the mounts.
beemerdevil
Re: Jack on diff
« Reply #4 on: 01 September 2010, 08:45:43 »
no, not advisable
Dave Elite
  • Ellesmere Port
Re: Jack on diff
« Reply #5 on: 01 September 2010, 11:20:58 »
Right thanks guys, I wont be doing that then. I saw my neibour lifting his mx5 up by the diff but thats a far lighter car. Thanks again :y
Re: Jack on diff
« Reply #6 on: 01 September 2010, 11:35:43 »
Doesn't mean he was right to do it, either ;)
A fair few 300ZX owners do the same thing after misreading the service manual; the lift point there is actually just behind the diff, not on the diff itself (there's a reinforced jacking point on the subframe).
Maybe there's something similar on the Omega? Most cars do have a central front & rear jacking point..
[edit] Except the Omega, it seems (having just looked in TIS)
« Last Edit: 01 September 2010, 11:45:13 by aaronjb »
Dave Elite
  • Ellesmere Port
Re: Jack on diff
« Reply #7 on: 01 September 2010, 16:47:55 »
I'd be interested to find out.
Re: Jack on diff
« Reply #8 on: 01 September 2010, 16:54:38 »
Like I say, I looked in the TIS and it only lists four jacking/lifting points (for a lift) on the chassis rails (at least that's what it looks like they're on) - no central jacking points front or rear..
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Jack on diff
« Reply #9 on: 01 September 2010, 17:05:20 »
In front I have jacked from the subframe just behind the sump. TO lift from it, I can not see any possibilities to damage whatsoever. From rear I have jacked also from the tow bar ( I have the Kovil tow bar, Finnish company). I know, someone will tell me not to bu tthe stress in jacking is less than the stress during a tow of 2500 kg trailer at the spped of 80 km/h...
