Author Topic: 2.6 cdx head gasket  (Read 2522 times)
puddsy
  • Borough Green, Kent
2.6 cdx head gasket
« on: 30 August 2010, 22:38:11 »
Hi to you all, I have just joined the owners club and I need some help, I have a 2003 Vauxhall Omega 2.5 CDX,
I have just had the cam belt changed and the garage told me that they had found oil in the header tank,
They cleaned out the engine and the colling system, it was then refilled and they let the car sit and run the car for a couple of hours to make sure it got good and hot, nothing happened and the car had no oil in the water header tank, since then three weeks have passed and now there is a good amount of oil in the header tank, I am hoping that the head gasket has not gone but cant think of what else it could be, if it is I would like to repair it myself, has anyone done this before and if so what sort of job is it to do,
Cheers Puddsy
Re: 2.6 cdx head gasket
« Reply #1 on: 30 August 2010, 22:40:18 »
Its the oil cooler and not the head gaskets ;)
Oh and welcome to the forum ;)
NF
  • Mid Cornwall
    • 2002 3.2 V6 Elite Estate
« Reply #2 on: 30 August 2010, 22:44:33 »
Sounds like oil cooler which is in the V of the engine between the cylinder heads. Try this link for guidance, http://www.omegaowners.com/forum/YaBB.pl?num=1211220529
Trade Card Holder
« Reply #3 on: 30 August 2010, 23:20:42 »
As others have said, 99.9% seems to be pointing to the oil coolers, this is situated between the 2 heads and the seals tend to deterioriate with the lack of proper ammount of anti freeze mixture.
« Reply #4 on: 31 August 2010, 00:43:53 »
Pudsy - if you put an approximate location in your details, there may be someone nearby who could be able to offer some assistance. :y
« Reply #5 on: 31 August 2010, 07:05:44 »
The oil coolers rot ;)
Dave Elite
  • Ellesmere Port
« Reply #6 on: 31 August 2010, 14:35:26 »
I've never heared of a 2003 2.5.
« Reply #7 on: 31 August 2010, 14:37:19 »
profile says 2.6, post says 2.5 so assume typo  :y
puddsy
« Reply #8 on: 01 September 2010, 21:11:41 »
Hi to you all and thanks to everone for the assistance,I did ask the garage about the oil cooler but he said that is not connected to the water coolant system, could the model mean that it is on a separate system or are they all the same?
I did think that as there is no loss of power or starting issues at all head gasket did not seem to be the problem, I am however a man who has not worked on an engine since points, rotor arms and condensors were taken away,
With reagrds to the 2.5cdx it was a typo 2.6 it is Doh!
Location is Borough Green, in Kent, TN158DL
Cheers Puddsy
« Reply #9 on: 01 September 2010, 21:13:33 »
Hi Puddsy. The oil cooler is water cooled and sits in the V of the engine under the inlet manifold.  ;)
« Reply #10 on: 01 September 2010, 21:16:41 »
As said mate. Have a look here:
http://www.omegaowners.com/forum/YaBB.pl?num=1209123017
and here:
and here:
http://www.omegaowners.com/forum/YaBB.pl?num=1192574209
and here too :y:
http://www.omegaowners.com/forum/YaBB.pl?num=1221081908
Hope you get it sorted mate  :y
« Last Edit: 01 September 2010, 21:21:57 by philrich1064 »
« Reply #11 on: 01 September 2010, 21:16:59 »
Cheers Puddsy
Change your garage as he dont know what hes talking about......and if hes this green hes not got a hope in hell of doing a good job changing it
The oil coooler is immersed in engin ecoolant in the centre of the V
puddsy
« Reply #12 on: 01 September 2010, 21:20:26 »
Hi There, I will get onto this job then when I come back off my hols, I think that even my limited abilities should be able to carry out this task (I hope)
Cheers Puddsy
« Reply #13 on: 01 September 2010, 21:21:32 »
Cheers Puddsy
Its not to hard, you will need a 19mm crowsfoot spanner....and use the correct sealent for the plate
Dont be tempted to bend the pipes to cut corners, it causes 'issues'
« Last Edit: 01 September 2010, 21:22:14 by Mark »
« Reply #14 on: 01 September 2010, 21:21:45 »
I wouldn't use the car in the meantime, it will make cleaning the cooling system even harder :(
Page created in 0.147 seconds with 16 queries.
