Author Topic: Flashing EML  (Read 3230 times)
377
  • Woodhall Spa, Lincs
Flashing EML
« on: 01 September 2010, 08:58:35 »
As many of you know, I have been changing the V6 for a TD for the past couple of weeks. After much rewiring I try to start it and when I put the key in the ignition and turn to allow glow plugs etc, the engine management light starts flashing. I suspect that engine imobilisor doesn't like my key now. I have changed the ECU and the ring around the ignition lock, but as the TD key I had didn't have a chip (i dont think) I thought my key would be fine, or is it having a hissy fit because my (V6) key does have a chip.
I get fuel and the glow plugs do their thing but it won't start
« Last Edit: 01 September 2010, 08:58:51 by R_Horton »
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
Kneepad
  • West Scotland
Re: Flashing EML
« Reply #1 on: 01 September 2010, 09:27:35 »
Any error codes ?
Re: Flashing EML
« Reply #2 on: 01 September 2010, 09:28:49 »
flashing eml with non starting does indicate an immobiliser issue.
Re: Flashing EML
« Reply #3 on: 01 September 2010, 09:32:29 »
.... I have been changing the V6 for a TD for  ......
surely much easier all round (insurance-modified cars) to have sold the V6 & bought a diseal  :-/ :-/ :-/
Kneepad
  • West Scotland
Re: Flashing EML
« Reply #4 on: 01 September 2010, 09:34:55 »
That's no way to get your hands dirty.   ;D
Re: Flashing EML
« Reply #5 on: 01 September 2010, 16:42:53 »
Ok, stupid question, do I have to change to control unit in the drivers?? passenger footwell too??
Regards
Richard Horton
charlie
  • sunderland
Re: Flashing EML
« Reply #6 on: 01 September 2010, 16:49:26 »
so you are using the chip from the v6 on the td ecu and reciever
Re: Flashing EML
« Reply #7 on: 01 September 2010, 19:14:39 »
As far as I can tell, I have 4 components to the immobiliser, ECU, control unit in the footwell, thing that fits on the steering column, and the key.
The V6 has a chipped key, the TD as far as I can tell doesn't (1996 MY).
I have swapped the ECU (obviously), and the bit under the steering column for the units from the TD. I have not yet changed the control unit (V6 unit still fitted) and I am using the V6 key (without chip).
So this leaves changing the ignition lock (to use TD key (unchipped)) and the control unit in the footwell.
I asume this is the next path, or am I wasting my time ??
It turns over on the starter, and I get fuel btw
« Last Edit: 01 September 2010, 19:16:00 by R_Horton »
Regards
Richard Horton
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Flashing EML
« Reply #8 on: 01 September 2010, 19:29:36 »
You will need the small little immobilizer chip that lives in the key too, this is read by the 'thing that fits on the steering column'.
You can try using the v6 chip and swapping back the steering column thing but I am pretty sure you will need the T.D. chip/transponder units to match the diesel e.c.u.
Re: Flashing EML
« Reply #9 on: 01 September 2010, 19:36:57 »
This is possibly where it gets complicated, as I think the TD key is an unchipped one ?? without the chip is in one of the lock blips (I wish I understood this more.... :D)
Regards
Richard Horton
Re: Flashing EML
« Reply #10 on: 01 September 2010, 19:43:42 »
The ECU, immobilser ecu (around the ignition barrel) and chip in the key are all coded together so you need all three of these items from the original tractor
Brikhead
  • West-Mids.
Re: Flashing EML
« Reply #11 on: 01 September 2010, 19:51:31 »
Vauxhalls have used this set up for years, I'm sure any Omega should have the chip in the key.
Click on the link for a picture of the chip and it's location within the key...
http://www.astraownersclub.com/vb/showthread.php?t=253962
Re: Flashing EML
« Reply #12 on: 01 September 2010, 19:53:59 »
So the key has a chip in it then, even though it has no blip buttons on it... (hmmm... can't find a confused smiley)
Regards
Richard Horton
377
Re: Flashing EML
« Reply #13 on: 01 September 2010, 19:57:55 »
My V6 key looks like that, the tractor key I have doesn't (sadly at work and no way of posting a picture)
Regards
Richard Horton
Re: Flashing EML
« Reply #14 on: 01 September 2010, 19:59:15 »
Simple to answer that.....does the original car have the immobiliser ecu around the ignition (the diesel).
And yes, earlier units had a key nad a seperate rf remote (and even earlier ones an IR one!)
