Pages: [1] 2 3  All   Go Down
Author Topic: Knocking Sound from Clutch  (Read 4764 times)
Vulpine
  • Kent UK
  • Omega 2.5TD The Vegmega!!
    • Omega 2.5TD '97
« on: 09 March 2010, 21:31:11 »
Hi All
Had my Omega now 5 years and it has always had this knocking sound from the clutch. Only does it at idle. Gets louder with clutch pedal down. Any ideas what it could be? Doesn't seem to get worse as the years pass or affect the driving of the car.
I have some ideas what it might be but will let you suggest first.  ;)
thanks
Jon
Admin edit
Re: Knocking Sound from Clutch
« Reply #1 on: 09 March 2010, 21:38:21 »
Dual Mass Flywheel at a guess
Omegatoy
  • UK
« Reply #2 on: 09 March 2010, 21:47:09 »
mdtm is correct!! same reason i had to change mine!!!
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #3 on: 10 March 2010, 07:04:18 »
ah OK. I feared that answer.
Is it expensive/difficult to replace?
Admin edit
Welung666
« Reply #4 on: 10 March 2010, 07:50:48 »
Buypartsbuy have about the best price I've found for a DMF, easy enough job if you're confident with a set of spanners. I'd recommend fitting a new clutch kit at the same time though :y
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #5 on: 14 August 2010, 00:16:42 »
OK clutch now slipping so I need to replacve it and the DMF. Any more leads or part numbers?
Any pics or guides? Are the bell housing bolts ok to get to?
please help....
Jon
Admin edit
Welung666
« Reply #6 on: 14 August 2010, 05:28:05 »
Fairly easy on the tractors, shame your not closer as I've got clutch changes down to a fine art now!
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #7 on: 14 August 2010, 09:26:20 »
lol i was driving back from Wales yesterday, could of popped in!
Admin edit
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #8 on: 14 August 2010, 16:47:36 »
ok looking at http://www.buypartsby.co.uk/clutch-parts-buy.php on part number 624165209 it talks about: If Std bearing fitted use 624 1652 00. Anyone know what this means? Would i have standard bearing (release bearing i presume)?
624165233 is a "pro" kit. What's the difference?
thanks
Admin edit
Welung666
« Reply #9 on: 14 August 2010, 17:29:37 »
You won't have the standard bearing, the release bearing is part of the slave cylinder and will set you back £100 on it's own. When my clutch went I assumed it was the DMF until I took the old pressure plate off and it had seperated into 2 pieces. DMF was fine but fitted the new one as I'd got it anyway. If it is your DMF then I've got my old one here.
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #10 on: 14 August 2010, 17:46:07 »
ah sound like i need to order a clutch kit from someone and then see what i find when i take her all apart.
« Last Edit: 14 August 2010, 17:46:28 by vulpine »
Admin edit
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #11 on: 15 August 2010, 09:38:34 »
so would the process go something like this?
1) jack up v high and support car
2) remove engine shield
3) disconnect prop
4) disconnect gear linkage (how?)
5) remove any wiring, hydraulics etc
6) support gearbox
7) undo bell housing bolts
8) remove gearbox mount
9) drop gearbox
10) remove clutch housing and plate
11) remove flywheel
missed any thing? is any step a real git requiring special tools or magical powers?
Admin edit
Welung666
« Reply #12 on: 15 August 2010, 11:04:12 »
3) disconnect prop
6) support gearbox
9) drop gearbox
11) remove flywheel
1) I cheat and use a kerb... reverse 3 or 4 foot accross a pavement then drive forwards up a set of ramps. Gets the car high enough and fairly level (ideal for autobox fluid checks too ;) )
4) Pop the square rubber boot off the bottom of the stick and you'll see a round metal pin with a spring clip each end. Just take off 1 clip and slide the pin out. EDIT TO ADD: take the 2 horizontal 10mm bolts out of the end of the selector while you're there, they are easily missed.
5) Reverse switch plug, lambda wires are just clipped on so pop the metal clip off. Hydraulics disconnect from the clutch master cylinder on the bulkhead, small bladed screwdriver to pull the small metal retaining clip out but careful you don't lose it! Also a hose clip on the bulkhead holding the pipe firm.
6.5) Remove starter motor, so battery off before you start and leave it hanging on the wires.
The rest is pretty much right :y
« Last Edit: 15 August 2010, 11:05:58 by Welung666 »
tidla
  • solihull
« Reply #13 on: 15 August 2010, 11:30:43 »
3) disconnect prop
6) support gearbox
9) drop gearbox
11) remove flywheel
as there is a fair amount of jiggling around, if you have the kit put the vehicle on two sets of opposing ramps so its level and very secure.
£30 gearbox cradle is safe investment.
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #14 on: 15 August 2010, 12:56:04 »
nice one, sounds ok
i'll try to write a point by point with pics when i do it all.
what does a gearbox cradle look like?
Admin edit
Pages: [1] 2 3  All   Go Up
