Author Topic: v6 misfire  (Read 919 times)
vauxhallvauxhall
v6 misfire
« on: 12 September 2010, 11:11:55 »
v6 facelift  misfire after belt change any suggestions
Re: v6 misfire
« Reply #1 on: 12 September 2010, 14:42:49 »
Yes, urgently recheck your cam belt / crankshaft settings before you run the engine any further!!! :o :o :o
Did you use a locking kit?? :-/ :-/
« Last Edit: 12 September 2010, 14:43:19 by Lizzie_Zoom »
beemerdevil
Re: v6 misfire
« Reply #2 on: 12 September 2010, 15:02:42 »
hmmm .... deffo check belt again - sounds like a tooth out? - i had this before (on my van); rechecked; was a tooth out (must have slipped on fitting) - reset, - OK  :y :y
  • Auckland
    • Mazda MPV
Re: v6 misfire
« Reply #3 on: 12 September 2010, 16:59:26 »
Also check for trapped wires in the cable duct across the front of the engine. A favourite is the knock sensor cable.
Jinglemaster2
Re: v6 misfire
« Reply #4 on: 12 September 2010, 17:19:40 »
O rings on plenum. Check they are all still there!
