Author Topic: just a quicky  (Read 1636 times)
brian36
  • Milton Keynes
  • 2.6 mv6
just a quicky
« on: 06 September 2010, 20:20:37 »
hi can someone tell me if there is a way you can reset service light on a 51 plate omega 2.2cd ? many thanks
« Last Edit: 06 September 2010, 20:20:59 by brian36 »
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: just a quicky
« Reply #1 on: 06 September 2010, 20:38:41 »
Many code readers will reset it.
Re: just a quicky
« Reply #2 on: 06 September 2010, 20:40:52 »
its not a service light....its a fault light.
fix the problem and it will go away  :y
unfortunately reading the codes is not easy on a 2.2 and requires a code reader normally (you can try the pedal trick, but unlikely to work)
Kneepad
  • West Scotland
Re: just a quicky
« Reply #3 on: 06 September 2010, 20:43:27 »
Read in another thread, this seems to work on a Vectra.
Might be worth a try.
Turn Ignition Off
·      Hold Trip Reset In
·      Turn Ignition On
·      Still Holding Trip Reset wait for three dashes
·      Turn off Ignition
brian36
  • Milton Keynes
  • 2.6 mv6
Re: just a quicky
« Reply #4 on: 06 September 2010, 20:49:15 »
many thanks to all ,looks like im going to have to talk nice to hotel21 ,many thanks :)
hotel21
  • The Kingdom of Fife
Re: just a quicky
« Reply #5 on: 06 September 2010, 22:52:40 »
Might be a wee problem there.  My Tech2 seems to have thrown its toys out the pram for some reason and is now refusing to answer button presses.....  >:(
  • Online Online
Re: just a quicky
« Reply #6 on: 06 September 2010, 22:55:46 »
Turn Ignition Off
·      Turn Ignition On
·      Turn off Ignition
this works on an Astra G too  :y this is cos both cars use a LCD display for the odometer & trip  ;)  ;)  ;) Omegas use the old fashioned mechanical barrel numbers  :y
Kneepad
  • West Scotland
Re: just a quicky
« Reply #7 on: 06 September 2010, 23:22:30 »
Turn Ignition Off
·      Turn Ignition On
·      Turn off Ignition
Cheers Andy, I learn something new every day on this forum.
whippit
  • Kirkcaldy, Fife
Re: just a quicky
« Reply #8 on: 15 September 2010, 12:43:03 »
Update on this as I bought the car off Brian.
Had the codes read
P0700 MIL request from Transmission Control Module
Caused by
P1870 Torque convertor Clutch stuck off
Reset codes and took it for a blast, no repeat so hoping its just a glitch as it had a recent box change.
« Last Edit: 15 September 2010, 12:44:50 by whippit »
