Author Topic: Vamps Airbag Problem  (Read 1257 times)
« on: 18 September 2010, 20:43:46 »
Hopefully, one of you kind and very bright folk will be able to decipher this info from Vamps car concerning his airbag fault?
The ECU had recorded faultcode 00055- Replace Electronic Control Unit-Not Present
However when the fault was cleared it reappeared instantly.
The following is Live Data -
[PROGVER]      "My Naff Code Reader" 081016 - PC based diagnostic tool
[TIMESTAMP]      18/09/10 16:25
[WSINFO]      Omega B
[MODELINFO]      2003      Omega-B      Body      Airbag
[ECUINFO]      KW82 protocol initialized.      ECU ID= EF      24420101      S0351162      4453J9      2103
[MBLOCKSINFORMATION]
[SELINFO]      0      0      0      0      0      0      0      0      0      0      0      0      0      0      0      0      1      2      3      4      5      6      7      8      0
Idő      Variant-Coding      Version      Airbag Configuration      Pretensioner Configuration      Side Airbag Configuration      Curtain Airbag Configuration      Seat Occupied Detection      System Voltage      System Voltage Status      Driver Airbag Squib Circuit Resistance      Passenger Airbag Squib Circuit Resistance      Driver Pretensioner Circuit Resistance      Passenger Pretensioner Circuit Resistance      Driver Side Airbag Squib Circuit Resistance      Driver SAS Message Status (Side Airbag Sensor)      Passenger Side Airbag Squib Circuit Resistance      Passenger SAS Message Status (Side Airbag Sensor)      Reset Pretensioning Devices After Activation (DTC67)      Reset Driver Side Airbag After Activation (DTC68)      Reset Passenger Side Airbag After Activation (DTC69)      Passenger SAS Communication Error (Side Airbag Sensor)      Driver SAS Communication Error (Side Airbag Sensor)      Driver SAS Initialisation Status (Side Airbag Sensor)      Passenger SAS Initialisation Status (Side Airbag Sensor)      DTC set since
sec                                                V            Ohm      Ohm      Ohm      Ohm      Ohm            Ohm
0.01      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.51      2.23      2.33      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
0.31      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.25      2.25      Okay      2.23      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
0.71      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.51      2.25      2.33      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
1.1      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.56      2.25      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
1.51      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.51      2.28      2.3      Okay      2.23      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
1.9      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.7      Okay      2.74      1.97      2.51      2.25      2.3      Okay      2.15      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
2.48      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.7      Okay      2.74      1.97      2.56      2.25      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
2.69      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
3.08      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.7      Okay      2.74      1.97      2.51      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
3.49      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.23      2.3      Okay      2.23      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
3.88      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.28      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
4.27      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.51      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
4.68      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.51      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
5.07      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.28      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
5.47      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.56      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
5.87      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.7      Okay      2.77      1.97      2.56      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
6.25      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.59      2.25      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
6.66      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.25      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
7.05      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.7      Okay      2.77      1.97      2.51      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
7.46      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
7.84      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.77      1.97      2.54      2.23      2.3      Okay      2.23      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
8.24      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.54      2.23      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
8.64      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not Used      Not Used      13.89      Okay      2.74      1.97      2.51      2.25      2.3      Okay      2.2      Okay      Inactive      Inactive      Inactive      None      None      Okay      Okay      0
9.03      0C      SAB6x      Driver&Passenger      Driver&Passenger      Driver&Passenger      Not
tidla
  • solihull
Re: Vamps Airbag Problem
« Reply #1 on: 18 September 2010, 20:54:17 »
i dont know. what i do know is that if you change the ink colour to green and use the mouse scroll wheel quick enough, it looks like youve entered the "matrix" :y
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #2 on: 18 September 2010, 20:56:45 »
;D ;D ;D Sorry Phil, but that was funny  ;D
« Reply #3 on: 18 September 2010, 21:05:45 »
No need to be sorry lads, I see the funny side of most things myself now  ;D ;D ;D ;D ;D :y
Oh, and I suppose it also means that you two are neither kind nor very bright? ::) ;D ;D ;D ;D ;D ;D ;) :y
« Last Edit: 18 September 2010, 21:08:13 by philrich1064 »
« Reply #4 on: 18 September 2010, 21:27:39 »
just exporting the data rather than using the record feature would have been a lot more readable  ;D
« Reply #5 on: 18 September 2010, 21:30:34 »
should add, those values all seem ok, but the proper log would have been better  :y  no high resistances, all circuits look ok.
jonnycool
« Reply #6 on: 18 September 2010, 21:32:16 »
I can't help you with your problem if that's what you mean, no  :-[ :-[ :-[
« Reply #7 on: 18 September 2010, 22:22:44 »
Bl**dy Hell Jonny, don't you go all funny on me as well!, I wont sleep tonight for fretting now! :-? ;D ;D ;D :y
« Reply #8 on: 18 September 2010, 22:24:07 »
Thanks for that jimbob :y
I did say in my OP you were dealing with a monkey! ;D ;D ;D :y
jonnycool
« Reply #9 on: 18 September 2010, 22:39:37 »
Don't worry Phil, my sense of humour is still intact mate  ;D
