Author Topic: 3.2 idle problems/surging  (Read 1967 times)
dieseld4
  • Tyrone,N.Ireland
« on: 30 September 2010, 22:03:18 »
Hi I have a 3.2 when taking over the rpm's will surge up to about 2000rpm and back down to normal about every 5 seconds or so, I've changed the throttle bodies and it didn't help, there is no fault codes.
Has anyone any ideas what the problem is?
Breaking all types of omegas, petrol and diesel, Items can be listed on ebay, I have 100% feedback
2woody
  • Northumberland
Re: 3.2 idle problems/surging
« Reply #1 on: 30 September 2010, 22:50:18 »
what do you mean by "taking over" ? is that when overtaking something ?
« Reply #2 on: 30 September 2010, 22:51:30 »
Assuming you mean "ticking" over, check for vac leaks
dieseld4
  • Tyrone,N.Ireland
« Reply #3 on: 30 September 2010, 23:23:58 »
Yeah I mean ticking over, I'll check for vac leaks tomorrow.
Thanks for your help
24_Valve
  • Greater London
« Reply #4 on: 01 October 2010, 01:37:36 »
I don't know if you have an Idle Control Valve on the deisel?  Someone please correct me if you don't. But if you do, then remove it from it's rubber housing (1 x jubilee clip at front & unplug electrical connector at rear) Clean it with loads of carb cleaner & replace :y
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
« Reply #5 on: 01 October 2010, 09:38:29 »
Not on a diesel no, but in his original post he says "I have a 3.2" which would mean DBW and as far as I know, no idle control valve (the ECU just moves the throttle butterflies to control the idle)..
« Reply #6 on: 01 October 2010, 09:43:34 »
Sounds to me like the engine is accelerating due to an air leak or similar until it hist 2,000 RPM where the ECU realises that it's uncommanded and cuts fuel.
Look for air leaks, as said. It would also be worth taking the throttle body off and giving it a good clean, IMHO, in case it's sticking.
Also worth doing a pedal test to see if there are any codes stored.
« Reply #7 on: 01 October 2010, 10:00:52 »
this the same car with the TC light on after the gearbox change?
The ABS ECU config does have a bearing on Idle..
I had a blank config on mine which caused bad idle and stalling, the correct program fixed these issues  :y
« Last Edit: 01 October 2010, 10:01:04 by jimbob »
  • Woodhall Spa, Lincs
« Reply #8 on: 01 October 2010, 21:49:00 »
[hijack]
Is this true on a TD ??
[/hijack]
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
24_Valve
  • Greater London
« Reply #9 on: 01 October 2010, 23:35:06 »
Posted by: aaronjb Posted on: Today at 09:38
24_Valve wrote Today at 01:37:
My mistake was looking at model stated beneath avatar and hazarding a guess... should have read OP properly, Anyway haven't a clue what DBW means so I'll leave to the experts  :y
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #10 on: 02 October 2010, 00:52:39 »
I'm no expert but DBW is Drive By Wire - no throttle cable.  So, as all throttle movements are controlled by the ECU anyway, there is no need for a separate idle control valve.
I feel like a military academy. Bits of me keep passing out.
24_Valve
  • Greater London
« Reply #11 on: 02 October 2010, 01:25:20 »
thanks Osprey didn't know such things existed... never seen a car without a throttle cable  ;) ;D
dieseld4
  • Tyrone,N.Ireland
« Reply #12 on: 02 October 2010, 09:23:58 »
Problem sorted, car was converted to gas but it was switch off, one of the little pipes which injects gas into the inlet manifold had split and the car was drawing air through it.
Thanks alot everyone for your help! ;)
