Author Topic: Dipstick  (Read 1995 times)
swiss
  • Southampton
Dipstick
« on: 03 October 2010, 13:04:28 »
Hi guys, sorry to be asking such a noobish question but it's kind of important. On the dipstick, I have two notches and two round dots embossed on the flat above them. Am I right in thinking the two notches denote max and min oil level, not the dots?
Also, the car's just recently started giving an irregular grunt, a noise I've previously associated with a lack of oil. Upon dipping this morning the level was about 75% the way between the two notches.
Cheers d00ds
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Dipstick
« Reply #1 on: 03 October 2010, 13:12:18 »
All the ones that I've seen have two groove-lines on 'em, obviously for 'min' and 'max' levels.
If you want to be absolutely certain, do a complete oil/filter-change to ascertain.
Total capacity is 6.5 litres.
HTH :y
« Last Edit: 03 October 2010, 13:13:07 by Reliance505 »
swiss
  • Southampton
Re: Dipstick
« Reply #2 on: 03 October 2010, 13:17:29 »
Very true, and it is overdue for a change, but first I've got to figure out what I'm doing with the drippy sump >.<
Speaking of which, has anyone had any success with a helicoil on the sump drain? And does anyone know what size thread the drain plug is? Ta muchly ^_^
« Last Edit: 03 October 2010, 13:17:52 by swiss »
Seth
Re: Dipstick
« Reply #3 on: 03 October 2010, 13:29:11 »
Yes ......... and no to be honest ..........  :D
Helicoiled the latest tractor, but found that it was the actual cast boss that was cracked.
Have done a repair with chemical metal paste, which has been successful to date. Planning on fitting the sump off my spare X25DT next week - sub-frame off etc.
Will get the cracked sump professionally welded in the near future.
To avoid this re-occurring, I've invested in a syphon pump - and it saves crawling around underneath too!
Syphon will easily pay for itself with the amount of oil-changes here anyway.
 ;D
« Last Edit: 03 October 2010, 13:30:57 by Reliance505 »
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
Re: Dipstick
« Reply #4 on: 03 October 2010, 13:48:16 »
need to helicoil mine really...  I use gasket sealent paste around the sump plug on mine, helps but not cures...
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
Re: Dipstick
« Reply #5 on: 03 October 2010, 14:05:40 »
If its the same as the v6 its 14x1.5 ..  I've got helicoil kits and sump repair kits if you need one let me know and we'll sort something out..
lee
Kneepad
  • West Scotland
Re: Dipstick
« Reply #6 on: 03 October 2010, 14:25:17 »
DodgeyDave
  • Northumberland &amp; London
Re: Dipstick
« Reply #7 on: 03 October 2010, 17:02:21 »
Sump plug is M14 x 1.5
You'll need a torx 45 bit to remove it.  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Dipstick
« Reply #8 on: 03 October 2010, 17:27:25 »
I did this, and it has been OK ever since: http://www.omegaowners.com/forum/YaBB.pl?num=1199559682/4#4 HTH :y
davethediver
  • Blackburn, Lancs.
Re: Dipstick
« Reply #9 on: 03 October 2010, 18:03:06 »
Or a 17mm socket depending on the age ;)
P.A. Caron de Beaumarchais
Shackeng
  • Ramsbury
Re: Dipstick
« Reply #10 on: 03 October 2010, 18:33:07 »
I think mine was 17mm hex before I went oversize as above. :y
