Author Topic: error code 19 but...  (Read 2398 times)
Richie London
  • heathrow
« on: 05 October 2010, 18:26:26 »
started running bad on friday then by sinday hardly any power at all, feels like its gonna stall at the lights, misfiring
ive checked leads and plugs, all seem ok. only put on in last few months. checked breathers and all associated with plenum.i changed crankshaft sensor for 1 i have had in the cupboard for a yr and a hf.  maff air sensor was renewed about 3 months ago.  all i can think of is the crankshaft sensor i put on is no good even though it was ok when i took it off other mig and only 3 months use, or my dispack is knackered. do i go and buy another crankshaft sensor, or get a dispack or any other possible cause
all advice greatly welcome.
thanks, rich
Re: error code 19 but...
« Reply #1 on: 05 October 2010, 18:28:00 »
If you have a 19, you have your clue  :y
Richie London
  • heathrow
« Reply #2 on: 05 October 2010, 18:33:38 »
which is cranshaft sensor. lol. so my spare one is no good then.  :(
« Reply #3 on: 05 October 2010, 18:40:41 »
it could still be from your old sensor ... unless you cleared the code errors when you changed to your used crank sensor.  :-/
Richie London
  • heathrow
« Reply #4 on: 05 October 2010, 18:49:01 »
i havent cleared the codes but do you need to, all i did was replaced the sensor, but no change in way car is running.
Richie London
  • heathrow
« Reply #5 on: 05 October 2010, 18:49:54 »
code 19 only came up yesterday, wasnt there in the week.
Richie London
  • heathrow
« Reply #6 on: 06 October 2010, 14:57:48 »
put a new crankshaft sensor on now i have codes 33  57 and 129 come up. car still running like shite. dont know what to do now. ??
« Reply #7 on: 06 October 2010, 15:03:29 »
33   Exhaust Gas Recirculation (EGR) Valve Voltage Low
57   Idle Air Control Voltage Low
129   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low
Welung666
« Reply #8 on: 06 October 2010, 15:03:33 »
Clean your EGR valve ;) :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #9 on: 06 October 2010, 15:08:07 »
all of those codes are low voltage faults with egr and idle air control,has the battery run low while you have been doing the crank sensor and is the charge rate ok?
other rides
« Reply #10 on: 06 October 2010, 15:09:33 »
Clean your EGR with oven cleaner and then refit with a blanking plate
Richie London
  • heathrow
« Reply #11 on: 06 October 2010, 19:29:18 »
cleaned egr and iac. cant afford to spend anymore money and cant work till i get car fixed, new plugs new leads new crankshaft sensor new maff sensor. no money left in pot.
thanks for all your help
« Reply #12 on: 06 October 2010, 21:09:56 »
Fitted the leads correctly?
Blanked the EGR....you only need a drinks can as a tester!  :y
Richie London
  • heathrow
« Reply #13 on: 06 October 2010, 21:17:15 »
the misfire stopped when i put new leads on, then it just started agian the other day and now i have all this problem. i'll cut a piece of tin tomorrow and try blocking the egr off, error code 33 has gone but i have a 21 now instead but still the others.
Richie London
  • heathrow
« Reply #14 on: 06 October 2010, 21:25:03 »
i went out earlier and run the engine in the dark to see if i could see a stray spark coming from back of engine where dispack is but nothing.
still got
19 new cranshaft sensor today
33 vanished tonight
21 came up tonight
73 has been there since changing maff sensor
74 same as 73
57 cleaned out with carb spray
129
« Last Edit: 06 October 2010, 21:25:52 by richierich »
