Author Topic: Oil cooler changed  (Read 875 times)
VR4Dave
  • Lincoln
Oil cooler changed
« on: 09 October 2010, 08:52:44 »
Now then miggers, got the oil pipes back on ok and been flushing the coolant system most the afternoon (i've learned that is not a good idea to clean the header tank before initial flushing as it was a waste of time!!)
Couple of questions for the experts;
I seem to have a very slight misfire although I've done the pedal trick and have no codes, spanner light flashes repeatedly with no pauses, I think that means no codes stored.
Car was virtually empty of fuel so I could have picked up some crap, as I've put 10 litres in and fuel light is still flashing, so must be very low.
I've read the recent post about a V6 with rough idling, so I have a good idea of the course of action to take with this.
Is the steering heavier on an MV6 than a standard mig? I moved the car round on the drive (to a flushing location) and it seemed awful heavy compared to my CD. I can hear the noise of the PAS pump when I turn the wheel, not dugga dugga, more of a whirring. (I don't hear this noise on the CD)
Cheers in advance
Dave.
Welung666
Re: Oil cooler changed
« Reply #1 on: 09 October 2010, 09:06:29 »
Steering is a little heavier on the MV6, shouldn't be a whirring sound though. Have you checked the fluid level?
« Reply #2 on: 09 October 2010, 09:57:06 »
Cheers in advance
Dave.
It should be speed senstive if working correctly. At parking speeds you should easily be able to use just one finger.  :y  :y
VR4Dave
  • Lincoln
« Reply #3 on: 09 October 2010, 10:09:06 »
Fluid is a nice clear red colour and the resevoir is about half full, not sure on the level it should be.
car hasn't been driven for a couple of months, as i bought it with oil cooler fault. will be taking it for a run next week and will see how it goes.
Thanks for the replies. :y
hotel21
  • The Kingdom of Fife
« Reply #4 on: 09 October 2010, 12:16:47 »
Electrical assistance to the steering is adjustable via tech2 on both MV6 and Elite versions.  Perhaps yours has been altered from standard?
