Author Topic: Jobs list  (Read 2680 times)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
Jobs list
« on: 09 October 2010, 19:55:50 »
In no particular order...  ...
Rear Discs & pads, possibly also front.
Something like wishbones and or drop links
cam cover gaskets and O rings.
Cam belt & water pump,.
NCDC 2013 head unit front panel replaced.
OR , swapped out for 2015 and telematics..
right hand rear light bulb on GID
be quite nice to have the colour screen,  but not that worried,..
but damn it's a thing of beauty...
Daz, Pete, and anyone else,    if we can work something out ASAP for the major bits, i'd be extremely grateful.....      not only will i Pay, I'll cook/....     ask around....  it's worth it...
Re: Jobs list
« Reply #1 on: 09 October 2010, 19:57:10 »
Hell if you'll cook.. I'll do the work for you*
(*Work may involve a lot of araldite and a big hammer)
symes
  • oxford
    • R reg 940 volvo
Re: Jobs list
« Reply #2 on: 09 October 2010, 20:06:06 »
I live in oxford too you need help let me know!  :y
got a few jobs there you will be busy for a while BUT worth doin-I find things to do mainly to get away from rubbish on tv
Re: Jobs list
« Reply #3 on: 09 October 2010, 20:20:02 »
Very similar list to when I bought mine  :y
MaxV6
  • Oxford UK
Re: Jobs list
« Reply #4 on: 09 October 2010, 22:07:49 »
it's a fairly common list , and in this instance worth getting done...
Re: Jobs list
« Reply #5 on: 09 October 2010, 22:08:57 »
Got any solder tags Max?
If so, you can fix the 2013 front panel
joshwyatt
  • Oxford
Re: Jobs list
« Reply #6 on: 09 October 2010, 22:11:05 »
Max, don't forget the 0420 and 0430 codes. The emissions light isn't on yet, but eventually you'll want to move the sensors.
MaxV6
  • Oxford UK
Re: Jobs list
« Reply #7 on: 09 October 2010, 22:51:42 »
that too!   well recalled Josh.....    thanks ......   again .... :y
MaxV6
  • Oxford UK
Re: Jobs list
« Reply #8 on: 09 October 2010, 22:54:21 »
Not sure actually Mark....   i very very rarely use them....    but i might have some in the bottom of a parts bin....
sort of std spade connector-ish size tags?  or smaller ??
Re: Jobs list
« Reply #9 on: 10 October 2010, 10:27:55 »
Are the actual discs shot? If its just the pads, its a pretty quick job.  If discs need doing, or handbrake needs adjusting, get a load of penetrating oil on the bolts that hold the heatshields to bottom of car a few times before you attempt it.  Or do what I reckon the dealer did to mine - snap all the bolts, rip off heatshields, and never refit  >:(
You need to jack up and look for play. What are symptoms, just noise?
Whats wrong? Some idiot tried holding the facia to pull radio out? That snaps all the weak, brittle clips.
Change all 3 at same time, around £1 each :o from dealer
MaxV6
  • Oxford UK
Re: Jobs list
« Reply #10 on: 10 October 2010, 11:39:12 »
yeah Jaimee, the NCDC seems to be that, the CD carrier is Jammed....   i presume they knackered the front panel trying to get it out.
the suspension at the front is knocking....    over small bumps and that, and the thing does not seem as stable and "planted" on the road as I'd expect.
there's also some after market adjustable load levelling non std , Monroe  Shocks on the thing...   with a pressure gauge  and air valve in the driver side rear quarter cubby hole by the fuel filler servo.
trying to find a manual for them online....  but not had much luck yet....
MaxV6
  • Oxford UK
Re: Jobs list
« Reply #11 on: 10 October 2010, 11:40:56 »
and it's definitely rear discs..  not just pads...    they're ridged like a small rotary mountain range....
    • 530D M Sport, 330i Coupe
Re: Jobs list
« Reply #12 on: 10 October 2010, 11:46:57 »
That reminds me!  ::)
Do you have a CPC / Maplins / RS Components number for the right ones?
MaxV6
  • Oxford UK
Re: Jobs list
« Reply #13 on: 10 October 2010, 14:21:40 »
oh, yeah, and door check strap thingy on drivers door....      it's only creaking a little, but best get in early eh?
Re: Jobs list
« Reply #14 on: 10 October 2010, 16:48:21 »
Knocking from suspension more likely to be anti-roll-bar drop links than bushes, IMHO, but worth checking it all over anyway.
Wandering could be down to poor alignment (is it wearing inner edges of front tyres?) or just rubbish tyres.
