Author Topic: Excessive misting and condensation  (Read 3150 times)
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« on: 11 October 2010, 09:38:31 »
Hi all
X reg 2.0 16v omega estate gets really misted up even with the fans on. Particularly noticeable on cool damp days. I don't have the air recirculation on but maybe it is stuck? I have to open the windows for a while to clear, which is not so good when it is chucking it down here in Wales as it usually is! Any advice appreciated other than move!!
Sixstring
  • Lydney, Gloucestershire
Re: Excessive misting and condensation
« Reply #1 on: 11 October 2010, 09:45:14 »
Is Uckfield, east sussex close to Wales, then??    LOL!
You might just have a leak from the heater system water somewhere, mate, in all seriousness. are you losing any water??
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« Reply #2 on: 11 October 2010, 09:47:20 »
Have you checked the cabin filter & made sure the scuttle is unblocked as per the maintenance guide?
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #3 on: 11 October 2010, 10:07:09 »
I think it's got to be your scuttle drain, as already mentioned,good maintenance guide,fairly easy fix, so well worth a check out :y
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #4 on: 11 October 2010, 13:24:28 »
And while you are there check that the recirc flap is in fact working.  Its at the bottom of the hole where the scuttle drain lives.
Alan
Kieran
  • Dorset
« Reply #5 on: 11 October 2010, 20:23:36 »
The estates are prone to misting. I have always had a problem with mine and find that the only way to clear it properly is to have the air con on. Check the scuttle tray and replace the pollen filter as this may help. I also ensure that my windscreen is kept very clean and on the side windows i use an Anti mist product that you can pick up from Halfords. The downside to this product is that it can leave a smearing on the inside of your windows hence i don't recommend it on the front windscreen. You can also try leaving the load cover open as this will allow air to move more freely inside.
« Reply #6 on: 11 October 2010, 22:49:39 »
Yep - it was moved there by the last government  ;)
« Last Edit: 11 October 2010, 22:50:07 by dbug »
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #7 on: 11 October 2010, 23:34:11 »
My windscreen mists up easily without the air-con on as well. My scuttle drains are clear (it was worse when they weren't) and misting is always worse when you switch from air-con on to off
I would think that recirculating the air without air-con on would just move humid air round the cabin, so wouldn't solve the problem
« Reply #8 on: 11 October 2010, 23:53:18 »
But aircon dehumidifies air (because the water in the air condenses on the cold aircon unit - which is why a/c always has a drain to the outside of the car) - it's better to dehumidify air that's already been dehumidified than draw fresh humid air in and dehumidify that.. one way the air gets gradually less and less humid and the other, it doesn't.
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #9 on: 12 October 2010, 09:41:48 »
I seem to remember Mark DTM posted a procedure that reset the air recirculation flaps some time ago. This cured the problem for me but I can't remember the procedure. Anyone?
jonnycool
« Reply #10 on: 12 October 2010, 11:39:16 »
He doesn't say whether he has a/c or not, you are right about the recirculation otherwise, of course  :y
« Reply #11 on: 12 October 2010, 11:41:38 »
are the cubby holes at the back clear?  or full of junk, as these are part of the airflow iirc.
Omega_Dan
« Reply #12 on: 12 October 2010, 11:44:09 »
try and air the car if you can (on your drive) i left all the windows open on mine all day whilst i was home on a dry sunny day as i had a slight misting problem and now all is well.
berserkerboy
« Reply #13 on: 14 October 2010, 09:30:32 »
Sorry for the delay in replying to all your advice which is much appreciated. Uckfield is not in Wales else it would rain more!
Back to the condensation. I have aircon but it packed up in May. Probably just needs a recharge?
I keep the scuttle drains clear but will recheck. I will check that the recirculation flap is working and that the cubby holes in the rear are clear. I am not losing any water.
Thanks everyone.
bob.dent
  • Hertfordshire
« Reply #14 on: 14 October 2010, 09:49:19 »
Thanks everyone.
As I said above, there is a way to reset the starting position of the air recirculation flaps by holding certain buttons in together but I can't remember the sequence. I think Jimbob is going to be posting up a "How To" in the maintenance section soon.
