Author Topic: 64 Fuel Quantity Control Out of Range  (Read 8729 times)
Re: 64 Fuel Quantity Control Out of Range
« Reply #15 on: 26 September 2010, 18:04:04 »
No real black smoke, except when chugging on tick over.
What's the black smoke, if not overfuelling?
  • Woodhall Spa, Lincs
« Reply #16 on: 26 September 2010, 21:32:58 »
Fair point, well made  :y
« Last Edit: 26 September 2010, 21:33:38 by R_Horton »
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
377
« Reply #17 on: 27 September 2010, 18:58:41 »
More proof that something is slightly amiss, popped into my local garage for a chat and stuck the diesel probe up the exhaust.
Off load "P" or "N" (tick over) the smoke was all over the place 30-90% depending on how it felt
In gear ticking over <2% generally
Revving >1k then about 0.3%
Couple of things spring to mind
I have a manual TD ECU connected (The engine came from a manual car), I wonder if an ECU from an auto has a different map for tickover ?
Wonder if i've missed something out in the wiring between the autobox and the ECU ??
Regards
Richard Horton
Omegatoy
  • UK
« Reply #18 on: 27 September 2010, 19:14:01 »
so as  soon as its under load it sorts itself? is that what your saying  :-/
377
« Reply #19 on: 27 September 2010, 19:14:12 »
Bugger, might have answered my own question here... One thing I have left to connect is a relay (K13) to P/N signal and pin 26 on the ECU (anyone know what that does ?) PIn 26 on a manual goes to plug X3 pin 5 and goes to CRC (cruise ??)
Wonder what that lot does then ???
Regards
Richard Horton
377
« Reply #20 on: 27 September 2010, 19:14:52 »
appears to yep  :-/
Regards
Richard Horton
Omegatoy
  • UK
« Reply #21 on: 27 September 2010, 19:20:38 »
appears to yep  :-/
god thats strange, its old skool diesel apart from the elctronic throttle, so theory says it should be quite happy loaded or not,
what speed does it tickover at? is it stable or all over the place?
what happens if you just very very lightly press the accelerator? any difference does it smooth out slightly or not at all?
oohhh just thought try putting a blanking plate in the egr pipe at the throttle body just for a trial, unless you already have it blanked?
« Reply #22 on: 27 September 2010, 19:32:36 »
.. but... On a diesel you have all the air you like flowing through it, even at idle, so more fuel correctly injected just makes it run faster to a point. More fuel injected with the wrong timing or dribbling out of the injector instead of spraying, however,...
Might well be worth a try. :y
377
« Reply #23 on: 27 September 2010, 19:36:51 »
ticks over at 600 ish, seems happiest at 900+, except when in gear and  it ticks over at 600 happily, although takes a second or two to settle (excess fuel i guess)
I'll try blanking the egr valve off, I'm sure I can find something at work to block it off with  ::)
Regards
Richard Horton
« Reply #24 on: 27 September 2010, 19:38:43 »
EGR on a diesel should be fully open at idle so I doubt thats it.
« Reply #25 on: 27 September 2010, 19:45:18 »
I'm going to guess it tells the ECU it's in Park or Neutral..  ;D
Sorry, no real help, but.. I wonder if it tells the ECU to inject (much) less fuel as there's no gearbox load on the engine?
« Reply #26 on: 27 September 2010, 19:49:09 »
So what happens if it's not ??
Anyone spotted i'm a little out of my depth with diesels  :-[
Regards
Richard Horton
377
« Reply #27 on: 27 September 2010, 19:55:06 »
Not sure, I've searched for the ECU (DDE 2.11) schematic to no avail. Fuel injector pump I can work out is controlled by P68 and that seems to go to pins 1,2,35,39,14, 21 and in a convoluted way to pins 10 and 17 but externally it isn't connected to pin 26.. internally that may be a different matter.
The electronics and wiring I can get my head round if it's available, the internal bits (ECU) are a mystery and that really does not help.
Regards
Richard Horton
« Reply #28 on: 27 September 2010, 20:07:47 »
so, it was a diesel out of an auto and now its manual....let me consult my wiring info
« Reply #29 on: 27 September 2010, 20:09:02 »
Nothing, diesels of this era regulate the fuel, not the air and hence as long as there is some air it will combust fine
