Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: 64 Fuel Quantity Control Out of Range  (Read 8727 times)
Re: 64 Fuel Quantity Control Out of Range
« Reply #45 on: 27 September 2010, 20:47:32 »
Did it used to be a petrol then?
yep  :)... did you miss the thread  ;)
That I now can't find...  :-[
To many threads and to many members  ;D
  • Woodhall Spa, Lincs
« Reply #46 on: 27 September 2010, 20:49:20 »
Have you also connected
ECU        Autobox
Pin 40 to Pin 38
Pin 43 to Pin 26
Pin 50 to Pin 40 (I think, print is not clear)
43 to 24 i have, but now i'm not too sure about 50 to 40, (X2-2) GN. I have also spotted that it goes to TC which I completely ignored for the time being  ::)
And that might well be for a speed signal.....(of course it might not as well, it could be the power off signal)
Goes to DZM (instruments), but i don't have that bit of the wiring with me at work so can't remember where it connects.
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
« Reply #47 on: 27 September 2010, 20:57:13 »
Well you need to get it connected up fully first so we can rule that bit out  :y
« Reply #48 on: 27 September 2010, 21:02:55 »
Yep, think i'll go through the wiring again with a fine tooth comb, I thought I had snagged everything, but it's been nothing less that a nightmare trying to do this bit and it's easy to think because you have a wire the right colour at pin 50 and pin 40, i've not really thought if they are connected together at any point...
I'll report back...
Regards
Richard Horton
377
« Reply #49 on: 28 September 2010, 18:30:25 »
Anyone know where Y20 (injection regulation) lives ??
Regards
Richard Horton
charlie
  • sunderland
« Reply #50 on: 28 September 2010, 19:16:35 »
It may be on the very bottom of the diesel pump :y
charlie
  • sunderland
« Reply #51 on: 28 September 2010, 19:19:49 »
Yup thats where it is (it under adjustment and not regulation)
« Reply #52 on: 01 October 2010, 08:05:16 »
Me again...  :D
Still haven't manage to locate the component called Y20 which has a couple of wires (Red/White & White) coming out of it.
But on another note Omegatoy mentioned I may have knocked the timing out, is there a simple way to check this ? Haynes is a bit rubbish for the TD.
« Last Edit: 01 October 2010, 08:05:32 by R_Horton »
Regards
Richard Horton
Omegatoy
  • UK
« Reply #53 on: 01 October 2010, 14:45:51 »
Me again...  :D
stand to be corrected,
 the timing is set by coloured links on the timing chain >:( dont know of any other way of setting it except by someone who may have a dti gauge and the bosch equipment?
charlie
  • sunderland
« Reply #54 on: 01 October 2010, 16:30:18 »
It is on the bottom of the pump(the one inside the engine bay)it may be located inside the pump its self :y
« Reply #55 on: 01 October 2010, 19:49:14 »
Is this the one that on another post somewhere, someone has called it "Fuel Quantity Sensor" ?? erm which sort of brings this post full circle...  ;D
Regards
Richard Horton
377
« Reply #56 on: 01 October 2010, 19:51:00 »
Me again...  :D
Which does mean stripping the front of the engine down then ??  >:(  bugger  :-[ Still here's hoping it isn't that and I really have done something stooopid
Regards
Richard Horton
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #57 on: 01 October 2010, 20:11:58 »
Doesn't code 64 link with injector 4???
Or am I barking up the wrong tree....
charlie
  • sunderland
« Reply #58 on: 01 October 2010, 20:38:03 »
no, two different parts of the pump :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #59 on: 02 October 2010, 21:13:08 »
A problem with this injector will throw 81 or 82 - trust me! :y
Pages: 1 2 3 [4] 5  All   Go Up
