Author Topic: 64 Fuel Quantity Control Out of Range  (Read 8736 times)
377
  • Woodhall Spa, Lincs
Re: 64 Fuel Quantity Control Out of Range
« Reply #30 on: 27 September 2010, 20:11:05 »
EGR on a diesel should be fully open at idle so I doubt thats it.
So what happens if it's not ??
Anyone spotted i'm a little out of my depth with diesels  :-[
so, it was a diesel out of an auto and now its manual....let me consult my wiring info
Nope, diesel out of a manual and now an auto... mated to a confused petrol (late model) autobox ecu that needs a reprogram too....
Regards
Richard Horton
Drives  '99 Omega Elite TD (almost)  Auto Estate
« Reply #31 on: 27 September 2010, 20:13:34 »
Is pin 24 (Brown wire) on the ECU connected to chassis ground?
« Reply #32 on: 27 September 2010, 20:15:29 »
I guess cruise is not working unless you have removed K13 and connected pin 28 to F15 via the clutch switch
« Reply #33 on: 27 September 2010, 20:18:12 »
Pin 24 looks to be key, its connected to chassis 0V in Manual setups and direct to the autobox ecu in auto setups
« Reply #34 on: 27 September 2010, 20:20:32 »
Not anymore, that's been replaced with a wire from pin 31 on the gearbox ecu to pin 24 on ecu (Brown with White Stripe)
Regards
Richard Horton
377
« Reply #35 on: 27 September 2010, 20:21:37 »
No cruise, and I need to sort that out, but not important right now)
Regards
Richard Horton
377
« Reply #36 on: 27 September 2010, 20:23:46 »
Just going to double check that bit, but i'm sure it's right... (Trouble with working with a late model Autobox ECU and a early model engine ECU... two lots of wiring to check  ::) )
Regards
Richard Horton
« Reply #37 on: 27 September 2010, 20:23:57 »
So its gone from Manual to auto or auto to manual?
Kneepad
  • West Scotland
« Reply #38 on: 27 September 2010, 20:34:22 »
Well the only problem (other than the wrong coding for the autobox) I appear to be left with is Error 64.
I guess I may have a pipe or connector on the wrong bit, but there is nothing I can see.
For want of any other ideas, you may want to check the map sensor and it's vac pipe.
« Reply #39 on: 27 September 2010, 20:34:35 »
Have you also connected
ECU        Autobox
Pin 40 to Pin 38
Pin 43 to Pin 26
Pin 50 to Pin 40 (I think, print is not clear)
« Reply #40 on: 27 September 2010, 20:36:07 »
car has always been an auto (V6 petrol) doner car (TD) was a manual, but DVLA have restricted my licence to Auto only so I had to make the TD drive an autobox
so I guess the easy answer is manual to auto
Regards
Richard Horton
« Reply #41 on: 27 September 2010, 20:37:16 »
Did it used to be a petrol then?
« Reply #42 on: 27 September 2010, 20:42:46 »
ECU        Autobox
Pin 40 to Pin 38
Pin 43 to Pin 26
43 to 24 i have, but now i'm not too sure about 50 to 40, (X2-2) GN. I have also spotted that it goes to TC which I completely ignored for the time being  ::)
Regards
Richard Horton
377
« Reply #43 on: 27 September 2010, 20:43:41 »
yep  :)... did you miss the thread  ;)
That I now can't find...  :-[
« Last Edit: 27 September 2010, 20:46:41 by R_Horton »
Regards
Richard Horton
« Reply #44 on: 27 September 2010, 20:46:52 »
ECU        Autobox
Pin 40 to Pin 38
Pin 43 to Pin 26
And that might well be for a speed signal.....(of course it might not as well, it could be the power off signal)
Page created in 0.095 seconds with 16 queries.
