Author Topic: paper clip test results  (Read 1555 times)
andyc321
  • reading
  • doh
« on: 18 October 2010, 12:15:09 »
hi all, carried out paper clip test on my 98 3.0 v6 elite auto without the engine running and came up with code 19 which i believe is something to do with rpm signal. does anyone know what this means and what i need to do to rectify this?  many thanks in advance, Andy c.
Re: paper clip test results
« Reply #1 on: 18 October 2010, 12:21:33 »
Yup, your crank sensor is knackered, Get a new one from Vauxhall, and fit...
Job done  :y
Omega_Dan
« Reply #2 on: 18 October 2010, 12:27:23 »
where is the link to the paperclip test guide please guys?
« Reply #3 on: 18 October 2010, 12:30:34 »
all guides, and tests are in the maint guide index, top of that section, or click the link in my signature  :y
Omega_Dan
« Reply #4 on: 18 October 2010, 12:31:59 »
great, should have just looked. :y
andyc321
  • reading
  • doh
« Reply #5 on: 18 October 2010, 12:32:17 »
thanks jimbob i will give it a try, any idea of cost and is it an easy fix???
« Reply #6 on: 18 October 2010, 12:56:22 »
about £50 iirc, and not too bad, we have a guide...
basically unplug from under the scuttle, route new cable behind ABS pipes to keep it cooler, and replace sensor by oil filter.
