Author Topic: torque converter  (Read 2621 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
torque converter
« on: 27 October 2010, 23:39:43 »
When driving I feel as if my clutch is slipping on my 2.2 cd auto. having read that it is a torque converter could this be the problem. Not very clued up on this field. cheers in advance
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: torque converter
« Reply #1 on: 27 October 2010, 23:49:24 »
usually the bands check what colour the autobox oil is, another good test is hold foot on brake and in drive give a quick rev the car should either stall or struggle not to if this doesn't happen usually the bands are getting a bit thin, do you feel this in every gear?
Warning: Dates in Calendar are closer than they appear.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #2 on: 28 October 2010, 00:00:15 »
Could it possibly need an gearbox oil change?
Kneepad
  • West Scotland
« Reply #3 on: 28 October 2010, 01:13:07 »
Or even just a top up?
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #4 on: 28 October 2010, 01:32:44 »
Yep, Ive heard that. too.
« Reply #5 on: 28 October 2010, 02:10:51 »
First off mate check ATF level in gearbox and top up as necessary.
Next check ATF is clean (red) and not burnt - if it is change it and clean/replce filter.
Then worry about wear in box.
« Reply #6 on: 28 October 2010, 10:20:19 »
Actually, first up.. what do you mean by 'feel the clutch is slipping'?
Are you used to driving a manual car where there's a 1:1 relationship between change in engine speed and change in road speed? (Yes yes, I know it's not 1:1, but it is a fixed ratio in every gear)
If so then are you sure what you're thinking is 'clutch slip' isn't just how a torque convertor works (engine speed will rise & fall independently of road speed)?
Forgive me if I'm teaching you to suck eggs, so to speak.. but it's worth checking before you think there's something very wrong with your car!
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #7 on: 28 October 2010, 10:58:10 »
Then worry about wear in box.[/quote
Is there a how to on changing it? or is it straight forward
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #8 on: 28 October 2010, 11:02:07 »
Not 100% thats what it is. but having driving my Miggy everyday for about 2 years and you know when its not right. When I had an old car and the clutch was slipping before packing in al together. Well thats what it feels like. But as I said not 100% sure.
Omega_Dan
« Reply #9 on: 28 October 2010, 15:27:14 »
Rather than start a new thread where is the ATF top up located so i can check also :y
« Last Edit: 28 October 2010, 15:27:43 by Omega_Dan »
« Reply #10 on: 28 October 2010, 15:43:36 »
Under car drivers side, on side of g/box sump - 13mm level/top up plug.  Howto on here. ;)
Omega_Dan
« Reply #11 on: 28 October 2010, 15:45:33 »
Cheers! :y i was looking for a guide but couldnt see one.
Welung666
« Reply #12 on: 28 October 2010, 16:07:32 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #13 on: 28 October 2010, 16:08:01 »
Presume I could syphon out the oil and replace without having to strip off the sump. Would that work?
Omega_Dan
« Reply #14 on: 28 October 2010, 16:09:02 »
Cheers lee :y
